Visitors: 134
Total: 134
02: Home
42: Home
68: Pictures
92: Home
131: Home
1 2 3 ... 31 32 33 ... 103 104 105
Posted: Fri Jan 15, 2010 11:19 PM
Mounted up the rear 6x9 speakers in enclosures I picked up from Wallyworld today. Was hoping to get the fan shroud flaps/thermostat before the weekend to mount them up but oh well......
DutchBug
DutchBug
Posted: Sun Jan 17, 2010 01:01 AM
Today I worked on my 68 instead of my Baja. Installed a new exhaust. Got angry at the shop because I missed some clamps while I specificly asked for it but luckily I had some old ones lying around.
Also tried to fit in new headlight rubbers but again they send me the wrong stuff. I need a new shop...
Posted: Sun Jan 17, 2010 07:13 AM
sprayed the silver part of my baja today. turned out good. its not perfect, but hey, its a baja and it is definitely shines way more than the spray paint it had on it.
DutchBug
DutchBug
Posted: Sun Jan 17, 2010 01:58 PM
...but hey, its a baja...
My excuse Wink
OregonBoy
OregonBoy
Posted: Mon Jan 18, 2010 12:15 AM
Got my bug today and first thing i did was hit up five mile road. windey roads and gravel its a fun slider and i had alot of fun. learned how to drive the manual too and like to think that i learned pretty fast. it was way different then my 91 toyota PU and i enjoyed it alot. plan on keepin this one =)
Posted: Mon Jan 18, 2010 12:59 AM
Got my heater flap set (powder coated from volkaholic) with thermostat delivered Saturday, much to my surprise. Started pulling the fan shroud off w/o dropping the motor. This is where I'm pleased with deciding to raise the body 3" 'cause I don't think it would've came out as easily.
Once the shroud was out, I quickly realized that there were no holes or slots for the flaps. CRAP!! No! No! No! No!!!! So I went to cutting and drilling on it. Pretty close but still have some trimming to do since they rub the cylinder tins.
DutchBug
DutchBug
Posted: Mon Jan 18, 2010 01:22 AM
Nice work. And I can't get my shroud out without pulling the engine... hmm perhaps I'll raise my body afterall.
OregonBoy
OregonBoy
Posted: Wed Jan 20, 2010 03:58 AM
tightend down my very loose intake and cleaned my filter. also re gapped my points to .01600 from .03000. removed my pulley and will replace it when my part comes in tomoro
Posted: Wed Jan 20, 2010 04:05 AM
I covered the seats.
Posted: Wed Jan 20, 2010 05:03 AM
Laughing Yes you did,,
Posted: Wed Jan 20, 2010 05:48 AM
yesterday i picked up a set of those chrome center caps for my wheels and i installed hood pins in my front end. no more troublesome hose clamps Smile yay!
today i put a new set of lug nuts on the rear wheels. i also made a billet knob (matches all the knobs in my car) that goes where the cigarette lighter would be.
Rickman
Rickman
Posted: Sat Jan 23, 2010 04:17 AM
Opened up the dash/box on the rail to see what size bulb the alternator light takes. I had to remove the light assembly to be able to pull the insides out to see the lamp. Forgot a valuable lesson learned a long time ago but evidently forgot...disconnect the battery before pulling wires. One of the connectors came off and made contact with a mounting bolt. Sparks, smoke, melted insulation and a welded shut connector. Replaced wire and connectors. Said to hell with it, I'm ordering a couple of replacement light indicators. Embarassed
Posted: Sun Jan 24, 2010 05:52 AM
Spent about 6 hours working on the Ghia today. Made some supports for the front shocks, and added more bars to the interior cage.
baja17
baja17
Posted: Sun Jan 24, 2010 11:22 PM
sanded down the 1 piece got the black sprayed on this week i will get the red have to rewire entire sound system Sad
Posted: Mon Jan 25, 2010 05:11 AM
painted the blue section on my car today. will have to start putting stuff back on it tomorrow after i get out of school
5 Admin_AzBaja 6856 Baja Bugs on Wiki need...
285 MusicManiac 241862 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 62 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1330 Re: Had to go play in ...
0 Northmountainauto 1561 Shop Baja
