Latest: xbluegto
Overall: 3573
Visitors: 176
Total: 176
05: Event Calendar
20: Event Calendar
21: My Account
28: Event Calendar
29: My Account
32: Event Calendar
45: My Account
46: Event Calendar
47: Event Calendar
59: Event Calendar
60: Event Calendar
63: Event Calendar
64: Event Calendar
68: My Account
73: Event Calendar
75: Event Calendar
79: Event Calendar
80: Event Calendar
81: Event Calendar
89: Event Calendar
90: Event Calendar
95: Event Calendar
104: Event Calendar
109: Event Calendar
111: My Account
116: Event Calendar
130: Event Calendar
132: Event Calendar
142: Event Calendar
148: Event Calendar
155: Event Calendar
156: Event Calendar
158: Baja Forums
164: Baja Forums
166: Event Calendar
176: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Relays
Relays
Post Post subject: Re: Relays
Posted: Wed Oct 11, 2006 02:59 PM
<<<<< Likes the optima batteries. I have one in Zyla, and have used many of them over the years. If you have one that went bad fast, it was a defect. I usually get 3-4 years out of them. Plus you can mount them sideways if you want cuz they are a sealed battery. And no battery acid to rot the floor of your v-dub.
saltyslug
saltyslug
Posted: Wed Oct 11, 2006 09:18 PM
if you use switches to run the power make sure they are at least 15amp for IGN and 20amp for each pair of lights. if you go to the 100watt big lights try and use at least 25 amp or larger. I usually run relays with the bigger lights just so it has a direct contact through the relay, plus you can run tiny switches which look cool with LED's(I miss my last baja, lol).
The factory VW light switch is a good switch and cheap to replace. It can retain all the dimmer features and is simple to mount or keep stock.
running two batterys when there is a bigger current draw(loud stereo with small welder running 15inch woofers listening to deep purple)than what the alternator will just take longer to do the same damage on 2 batteries.
you wanna run a bigger amperage alternator. any thing else like extra batteries and caps is just like putting a bandaid on a ripped off leg. it might work for a while but it will eventually leave you for dead who knows where, and when its a baja or offroad vehicle thats a big gamble.
sorry so long but it is very important to do things the right way with these monsters, and for bugs its usually cheap. good luck
