Latest: strike77
Overall: 3575
Visitors: 153
Total: 153
03: Event Calendar
11: Links
42: Event Calendar
51: Pictures
64: Event Calendar
68: Event Calendar
71: My Account
75: Event Calendar
81: My Account
100: Event Calendar
104: Event Calendar
119: Event Calendar
135: Pictures
147: Event Calendar
149: Event Calendar
151: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 1500cc motor help
1500cc motor help
mikey
mikey
Post Post subject: 1500cc motor help
Posted: Wed Jan 13, 2010 01:32 AM
help plz........ i have 2 1500's that need the crankshaft seal,,,,,can i put the seal in without splitting the case? and where to get one that has the bump on the outside rim.... THANKS
everything looks better with mud on it
Post Post subject: Re: 1500cc motor help
Posted: Wed Jan 13, 2010 02:04 AM
You can put the seal in just by removing the flywheel. If there is an o-ring in the flywheel mounting flange make sure you replace that too.
IMPORTANT!!!!!!! MAKE SURE the flywheel is correctly torqued, if you dont torque it right the flywheel WILL COME LOOSE and reuin the crank and the flywheel.
You can get the rear main seal and flywheel o-ring at any VW parts supplier. I have them in stock, $10 shipped for both items.
mikey
mikey
Posted: Wed Jan 13, 2010 05:40 AM
did all of the above,,,,,the oil is coming from the CAMSHAFT seal not the crank seal,,,its about an inch in diamater and its located just below the main seal.it looks like a freeze plug, can i replace it without cracking the case? 1500cc vw motor
Posted: Wed Jan 13, 2010 07:10 PM
No you will have to crack the case to replace that.
mikey
mikey
Posted: Thu Jan 14, 2010 03:15 AM
i was afraid of that,THANKS dirtjunkie i bought it that way and it ran so well,,,i guess i'll go ahead and spend for 87mm. jugs and pistons.if i gotta go that far, this will be my 1st. rebuild,hope it runs,,,,,THANKS
No new posts VW Volkswagen & Baja Bug General Discussion Motor issues 12 Dirtjunkie 3853 Re: Motor issues
 Mon Sep 19, 2016 09:06 PM
No new posts Projects and Builds class 5 baja bug needs motor... 0 Azbugracing1214 2519 class 5 baja bug needs...
 Tue Jun 09, 2015 12:51 AM
No new posts Projects and Builds Where to buy ecotec 2.2 motor mounts? 1 cycleguy1979 2267 Where to buy ecotec 2....
 Sat Jun 30, 2012 01:41 AM
17 TwistedMetal 12830 Which trans with a 22r...
 Mon Dec 05, 2011 02:51 AM
chrispy56 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion awd motor for baja bug?? need some help 3 lzugl 2306 Re: awd motor for baja...
 Tue Jun 14, 2011 06:01 AM
