Visitors: 106
Total: 106
19: Event Calendar
58: Event Calendar
68: Home
90: Event Calendar
102: Event Calendar
104: Event Calendar
106: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- My Blue Baja Build...
Baja_Blue
Baja_Blue
Post Post subject: My Blue Baja Build...
Posted: Sat Jan 09, 2010 06:45 AM
New engine I got ended up having bad rings! low compression(90psi) on one cylinder and 95psi on the rest.
I had major oil leaking because of all the positive crank case pressure from bad rings.
This is at idle...
that would be abou 55psi!!
Called the guy up, he completely backs up his work fortunately. and he is replacing it with a new one tomorrow for free! woo!
Glad I at least bought an engine from a guy who isn't a scam
Matthew 5:14-16
Baja_Blue
Baja_Blue
Posted: Thu Jan 28, 2010 08:52 AM
wellll, looks like the the guy I got it from is pretty stupid. I got the new engine back(he put different heads and rings on), and I got it running and it would not stop popping from cylinder 1! adjusted the valves, set the timing, looked it over... did NOT know what was wrong.
took off the valve cover again cuz I figured the exhaust or intake valve was sticking.
The guy did not put the pushrod into the little hole on the rocker arm!!!! so the valves weren't even opening. all fixed now. car runs great!
Matthew 5:14-16
Posted: Fri Jan 29, 2010 12:02 AM
Glad you found it was an easy fix
Baja_Blue
Baja_Blue
Posted: Thu Sep 02, 2010 11:01 PM
Wow it has been a long time since I have updated this!
Things completed...
-Class 11 cage with alot more bars added
-IRS Conversion
-Cut and turned front beam, new bushings
-Summit Racing 10 Gallon fuel cell w/foam mounted behind the seats
-Two 6x9 Speakers and a Sub
-Replaced ALL brake lines, hardlines, wheel cylinders, and pads
In the works...
-Full front cage work to replace frame head
Matthew 5:14-16
jon6.0
jon6.0
Posted: Thu Sep 02, 2010 11:07 PM
Pics or it didn't happen...
1967 Baja
2005 GTO
2009 Speed Triple
Baja_Blue
Baja_Blue
Posted: Thu Sep 02, 2010 11:42 PM
lol for sure, I'll get some pics this weekend
Matthew 5:14-16
Baja_Blue
Baja_Blue
Posted: Wed Sep 15, 2010 03:40 AM
Haven't got the motor back in yet but here are the pics you requested.
Reinforced Tie Rods
Roll Cage
Rhino Liner On top and bottom of the pan
Before the IRS conversion was sagging a bit lol
Still sagging after conversion
Took the front suspension apart for a cut and turn. Ended up having to buy a new beam since mine was bent beyond belief so I bought an already cut and turned one and swapped all my parts from the old beam into it.
Finally Reindexed rear with IRS and Ball joint front end cut and turned
Fuel Cell mounted behind seats not completely finished yet
yeah, it happened jon6.0 haha
Matthew 5:14-16
Baja_Blue
Baja_Blue
Posted: Wed Sep 29, 2010 04:20 AM
Motor is in and the fuel cell is welded in!!
Also, VDO Voltmeter installed
Matthew 5:14-16
Baja_Blue
Baja_Blue
Posted: Sun Nov 14, 2010 08:23 AM
Snapped a clutch cable offroading in stoddard, that's okay, it was fraying anyways and needed replacing. There a big pain to replace...
pulled the pedal assembly...
Trying to find the tiny little tube to put the new cable into...
Matthew 5:14-16
Baja_Blue
Baja_Blue
Posted: Fri Nov 19, 2010 02:24 AM
NEW TORSION!!!!! 28mm 26-9/16" Sway a way!!!
These things are thick!
Matthew 5:14-16
Baja_Blue
Baja_Blue
Posted: Sat Dec 04, 2010 11:25 AM
Pictures with the new torsions in...
Also notched my spring plates 1/4"
AND, new Alternator!!!!
Up Next, VW Thing Axles/CV's. Type 2 Drive Flanges and stub axles!
Matthew 5:14-16
Baja_Blue
Baja_Blue
Posted: Wed Feb 23, 2011 03:17 AM
Got some Bilstein 5150 Shocks for the rear...
Mounted them today, I'll get some pictures tomorrow when it's light out.
Also replaced the master cylinder with a dual circuit, finally fixed the brakes problem!!
Matthew 5:14-16
5 Admin_AzBaja 7372 Baja Bugs on Wiki need...
1568 mufasavnvmc 1021064 Re: what did you do to...
285 MusicManiac 246537 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 486 FREE VW BAJA'S
