Visitors: 124
Total: 124
02: Event Calendar
05: Event Calendar
16: Event Calendar
20: Event Calendar
48: Event Calendar
50: Event Calendar
58: Event Calendar
97: Event Calendar
111: Event Calendar
116: Event Calendar
123: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- New to Bajas?
New to Bajas?
1 2 3 4 5 6 7 8 9
The following users give thanks for this topic Anonymous - Mon Mar 09, 2009 02:16 AM
Post Post subject: Re: New to Bajas?
Posted: Sun Mar 08, 2009 10:54 PM
big0067 wrote:
anybody know anything about wireing
Start a thread in the Electrical forum, and ask as many questions as you want! If you start a thread in the proper forum, you'll get a LOT more traffic, and a lot more help. Cool
big0067
big0067
Post Post subject: New to Bajas?
Posted: Fri Mar 13, 2009 05:03 AM
can you guys help with building a baja from start to finsh starting with a stock bug??
Posted: Fri Mar 13, 2009 06:02 AM
Here ya go. Start to finish, pretty much. In depth, with pics and EVERYTHING. The finished product from this article was a NICE baja.
http://www.chircoestore.com/catalog/articles.php?tPath=2
Mobyjack
Mobyjack
Posted: Sat Apr 04, 2009 06:19 AM
I read all the way through this post and since no one else mentioned it I thought it might be a good idea to tell you to plug up your heater air outlets in your fan shroud or you're going to fry the engine.
My all time favorite VW advertising line: The sophisticated alloy engine allows the Volkswagen to charge up the hills like the hounds on the heels of the hare. circa 1955
Posted: Mon Apr 06, 2009 04:22 PM
I've actually read the best action for this is to plug the outlets, but drill a 3/4" hole in the plugs. I believe it was Raby who discovered this gives better airflow through the shroud. Of course the best advise is a OEM shroud without the outlets, or a DTM if you $$ for it.
Mobyjack
Mobyjack
Posted: Mon Apr 06, 2009 11:23 PM
A 3/4 inch hole in the plug..., interesting. I'd like to see that information, not because I doubt what you say, just that I'd like to see why they would suggest it. For sure though, I think it'd be agreed, plugged outlets are better than no plug.
Posted: Tue Apr 07, 2009 04:31 PM
I read it quite some time ago in the samba performance section.
Posted: Tue Apr 07, 2009 05:31 PM
I'd say it has to do with causing some backpressure in the shroud, and therefore enhancing airflow- sort of a siphoning effect, if you will. Venturi effect probably plays in to the equation as well. The principle is probably similar to that of exhaust systems, etc.
Mobyjack
Mobyjack
Posted: Tue Apr 07, 2009 08:39 PM
Seems like it'd RELIEVE some back pressure not cause it. A venturi effect might make some sense if the mass flow rate has effectively been restricted by plugging the outlets to a point where it would need the relief created by drilling a hole(s) in the plug(s). Until someone does more research (and really I doubt anyone will Rolling Eyes ) I think I'd stick with just plugging them up. In the past I've seen freeze plugs used but the cheapest, and just as effective I'm sure, was a couple of baby food jar lids held in place with some machine screws. Of course here in the High Sierra I'll be running heater boxes anyway so I'm just speculating Rolling Eyes .
fabinc
fabinc
Posted: Sun Jun 21, 2009 07:02 AM
I want to advertise my shop on the front page. I click on the banner but it is unaccessible. I have money what is it going to cost me to put my company up here?
FunAssBuggies (FABINC.) Gilbert, AZ. (480)-219-2584
siacs
siacs
Posted: Sun Jun 21, 2009 03:20 PM
Paying customer Very Happy Very Happy Very Happy
Posted: Sun Jun 21, 2009 08:05 PM
Join as a AzBaja.com member and it $1 doller a month, give or take how long you want the add to be up etc...
nateinoc
nateinoc
Posted: Sun Nov 01, 2009 08:47 PM
i have a baja, it has bj front end and irs rear end. how are the bj frnt ends? are bj better than link or is link better than bj?are you limited more with bj frontend far as sus. should i put a link pin front end on the baja.I would like to get as much travel as possible up front. Would a 6" over beam and link pin help out a lot? I want to put 3x5 or 3x7 over trailing arms in rear. gonna put coilovers for sure but possibly bypass in rear also. any post or ideals would help. new to bajas but not to sandrails. I have a good grasp on welding and fab. what cage is a good cage to buy and build off of for sus. possibly put the cage then tube from there to the front and rear.. what do you guys think.. what should I do... thanks in advance!!!!
sweetcars
sweetcars
Posted: Thu Dec 17, 2009 06:20 PM
Hi everybody im living in montreal and im new to baja's I would like to know what is the different between these 4 baja wide eyes kit ..( CPRK102, CPRK201 , CPRK202 ,CPR821136 ) on this link
www.chircoestore.com/c...65vhhl70n4
I mean why the price is changing on tese for item cause they seem to be the same...
thansk for helping me..
Posted: Thu Dec 17, 2009 07:10 PM
I would call and ask. They are very nice.
they are also different styles and thicknesses. If it were mine I would use the extra thick wide eye kit. www.chircoestore.com/c...ts_id=1805
1 2 3 4 5 6 7 8 9
55 GHOSTRIDER 36173 hello from ghostrider ...
 Sat Apr 29, 2017 06:16 AM
GHOSTRIDER View latest post
[ Go to pageGo to page: 1 ... 10, 11, 12 ]
175 BugZyla.com 78606 BAJAS at SONIC Eastsid...
 Sun Jun 22, 2014 11:36 AM
No new posts New Members New to bajas from Vt. 14 vtbaja 8571 New to bajas from Vt.
 Wed Aug 14, 2013 08:18 PM
No new posts Events and Get Togethers World Wide Bajas, Bugs, and Buggies at Sycamore Creek-March 2nd
55 JWHracing 30552 Bajas, Bugs, and Buggi...
 Sat Mar 09, 2013 07:55 PM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Full bodied bajas 2 desertbaja 3472 Full bodied bajas
 Sun Aug 19, 2012 05:29 AM
sandfreaks View latest post
