Latest: slyster
Overall: 3568
Visitors: 135
Total: 135
03: Event Calendar
48: Event Calendar
71: Event Calendar
133: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cage ?
cage ?
neadspeed
neadspeed
Post Post subject: cage ?
Posted: Mon Dec 07, 2009 12:11 AM
I am wanting to put a roll cage in my baja, I know i'm going to use 1.5" dom. My question is do i use .095 or .120 wall, Thinking .120 wall but would that be over kill. My plans are to exstend 6" to 8" on the front with 6over beam, 3x3 or bigger in the rear. Not sure if i will be using torsion bars or coil overs As of right now i'm in South dakota Evil or Very Mad . But after a year or 2 we will be moving back to southwest so i know that i will be in desset playing again.
Blake22211
Blake22211
Posted: Mon Dec 07, 2009 12:31 AM
095 works great...all the class 11 roll cages use 095 and seem to protect just fine...
Straights are for fast cars...Turns are for fast drivers...
My Garage Link!
mccolery5
mccolery5
Post Post subject: Re: cage ?
Posted: Mon Dec 07, 2009 04:22 AM
i have a class 11 cage and 120' of 1 1/2 120 wall and my car wights 2060 it heavy but that meens i need a bigger motor
neadspeed
neadspeed
Posted: Tue Dec 08, 2009 12:01 AM
i think i will use .120 wall for bottom rails and main hoops. Then .095 wall for the rest of the cage. How many sticks of dom will i need to do a full cage like class 5 baja's
Blake22211
Blake22211
Posted: Tue Dec 08, 2009 07:47 AM
well...
""""Class 5: Vehicle must be a VW Sedan Type 1 Hardtop or Convertible as delivered from the factory.
Horsepower: 175-250
Wheel Travel: 12-18 Front, 18-24 Rear
Weight: 2200-2400
Top Speed: 105
Cost New: $50,000-90,000
Cost Per Prep: $4,000-8,000
Basic Rules: Front and rear suspension is open, as long as it retains stock concept. Length, width, and manufacturer is open, as long as the wheelbase does not exceed 105 1/2'' at ride height.
Engine Rules: Any manufacturer air cooled, 4 cylinder, single cam, pushrod, VW concept engine is allowed. VW 4 cylinder water cooled engines may also be used. Displacement is open."""""
Are you really planning on getting 175 to 250 horse out of your VW motor, ridiculous amount of travel front and rear, and have 4-8k just for race prep?? Shocked
If not, just go with class 5-1600 or class 11 roll cage...
If so, based on mccolery5..
Quote::
I have a class 11 cage and 120' of 1 1/2 120 wall and my car wights 2060 it heavy but that meens i need a bigger motor
I'd guess more than 120' haha Laughing Laughing
My Garage Link!
ChuckD
ChuckD
Posted: Tue Dec 08, 2009 08:06 AM
sweet bug blake. Must of had some serious momentum to do that.
Blake22211
Blake22211
Posted: Tue Dec 08, 2009 08:38 AM
That's not me...
www.thesamba.com/vw/fo...?p=3409215
I wish I raced! going to a local rally cross soon though!
My Garage Link!
ChuckD
ChuckD
Posted: Tue Dec 08, 2009 08:46 AM
Blake22211 wrote:
That's not me...
Nice link.
And I feel you're pain. Only raced once, and it was the sickest thing ever.
neadspeed
neadspeed
Posted: Tue Dec 08, 2009 02:37 PM
i was just using that class for reference for all the extra bracing. There is no way that i could afford that prep. thanks for all the input
Blake22211
Blake22211
Posted: Tue Dec 08, 2009 05:07 PM
Oh got it. yeah I'm probably guessing sponsors cover that cost. no problem, good luck with your cage man
My Garage Link!
Posted: Tue Dec 08, 2009 05:33 PM
Mine started with a bolt in cage for the 2 hoops. Then I think we used ~80-100 ft of 1.5 tubing and ~20 ft of 1.0. I want to re-do my rear bumper and planning on 2 sticks ~40 ft.
ChuckD
ChuckD
Posted: Tue Dec 08, 2009 08:15 PM
Thats how we started too. Accept the buggy caught fire half way thru the race, melted a couple tabs off, ran out of money for a rebuild, and now it the cage sits in a field rusting.
Blake22211
Blake22211
Posted: Tue Dec 08, 2009 10:17 PM
fire extinguisher?
My Garage Link!
ChuckD
ChuckD
Posted: Wed Dec 09, 2009 06:48 PM
It was too little too late. It was like a 12 ounce ABC or something. The important thing is, I still have the 1835 core, and all the money I put into that. AND nobody got hurt, just a couple cactus.
When we were diagnosing the mess some days later, we figured it was the manual fuel switch between tanks that sprung a leak, dropped my pressure and created an air pocket in the line after I switched the two tanks. The air pocket couldn't get past the second clogged fuel filter witch started spraying gas from the pressure. Fried the damn thing from the exhaust back into the cabin. Shocked And now im still using that 1835 block in my new baby.
Posted: Wed Dec 09, 2009 08:07 PM
sounds to me like you should be upgrading your fire extinguisher for the next time. just like a cage its a safety thing, don't skimp. I have a 3 lb one in my baja. its mounted on the tunnel just in front of the shifter for a quick grab on the way out of the car.
24 Kreed 20399 3" Body Lift, Class 11...
 Mon Apr 18, 2016 04:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion any info on this roll cage? 3 ghettodish 4312 any info on this roll ...
 Sat Oct 29, 2011 05:21 PM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Cage Install 12 1969Baja 10985 Re: Engine Cage Instal...
 Mon Sep 27, 2010 01:06 AM
No new posts VW Volkswagen & Baja Bug General Discussion What's a reasonable offer for this roll cage?
6 point 'SCORE legal'
1 Billy 2071 Re: What's a reasonabl...
 Wed Mar 31, 2010 12:34 AM
No new posts VW Volkswagen & Baja Bug General Discussion External roll cage
32 Buggyboat 66056 Re: External roll cage
 Fri Jan 08, 2010 04:03 PM
MusicManiac View latest post
