Latest: strike77
Overall: 3575
Visitors: 102
Total: 102
13: Event Calendar
22: Event Calendar
26: Event Calendar
31: Event Calendar
37: Pictures
43: My Account
44: My Account
55: Home
67: Event Calendar
68: Event Calendar
77: Event Calendar
84: Event Calendar
102: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cut the center beam
cut the center beam
1969Type1BAJA
1969Type1BAJA
Post Post subject: cut the center beam
Posted: Mon Nov 30, 2009 11:10 PM
i have the 002 trans and tried to use the drop down peace put ti wont get into 1st or 2nd so i want to cut the top of the beam from behind the e brake to the service hole and use swivel joints to make it nice and smooth what do any of you thank or what did you do
Post Post subject: Re: cut the center beam
Posted: Sun Dec 06, 2009 09:33 PM
Univerasals would be great but will not solve your problem unless you are very lucky when welding the assembly together. Your main problem is you need a weld in a Scat adjustable shifter rod end. One of the grub holes are misaligned by about an eight inch. I would try the adjuster first. The trick set up albiet more time consuming and expensive would be two universals and the adjustable rod end.
25 Kreed 23477 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Bent beam 1 cperry2704 938 Bent beam
 Tue May 30, 2017 03:38 AM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Center Mount Fan Shroud 4 Darn_Near 2837 Center Mount Fan Shrou...
 Sat Apr 12, 2014 05:13 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion dellorto 36 center mount 2 _-Mad-Max-_ 2461 Re: dellorto 36 center...
 Tue Jun 19, 2012 03:38 PM
No new posts VW Volkswagen & Baja Bug General Discussion Need a rebuild on my link pin beam 2 wideopenmotorsports 2597 Re: Need a rebuild on ...
 Wed May 18, 2011 01:38 AM
