Visitors: 116
Total: 116
03: Event Calendar
51: Event Calendar
53: Event Calendar
58: Event Calendar
68: Event Calendar
86: Pictures
94: Event Calendar
97: Event Calendar
98: Event Calendar
101: Event Calendar
113: Event Calendar
114: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- To lift or not to lift?
rgc3102
rgc3102
Post Post subject: To lift or not to lift?
Posted: Fri Dec 04, 2009 08:35 PM
Building my first baja from the pan up. Just installed the new warrior beam went, 6 inches wider with 10 inch coil over towers. Wow! didnt know the shock towers wold be so tall! Will be using a one piece front end. Will I need to go with a body lift to have enough clearence? Thanks
RGC
jon6.0
jon6.0
Posted: Fri Dec 04, 2009 10:49 PM
Trim the front end to fit.
Colesifer68
Colesifer68
Post Post subject: Re: To lift or not to lift?
Posted: Fri Dec 04, 2009 11:53 PM
i dont think he was talking about the front end.
rgc,
it depends on what size tire your going to be running. i have a 3" body lift on my baja and clear 34" swampers no problem. high mount rear fenders were needed to get the travel desired but they look cooler anyway.
if your going to put a 30-32" tire than i wouldnt think you will need one. the body lift does alot for it though. doesnt give you anymore ground clearance though.
what kind of suspension and tires are you looking to do with your car. sounds nice already!
rgc3102
rgc3102
Posted: Sat Dec 05, 2009 04:07 AM
I haven't really decided on tire size yet. I know it will either be 31's or 32's. I was however talking about the front end, I am hoping to get 10 to 12 inches of travel out of the front end. What I was concerned about was the clearence between the top of the shock tower and the one piece front end I plan to put on. Right now the body is off the car, I am real close to putting it back on but wasn't sure if I needed a body lift. Any and all advice is greatly appreciated.
RGC
Posted: Sat Dec 05, 2009 06:32 AM
A body lift will help several things: Obviously there will be more room for tires and the likes. If you're tall, it gives you more room inside (I'm 6'4"). One thing that you might not realize is that it actually strengthens the car and makes it twist less when off-roading. This helps reduce body fatigue and cracking, and actually makes the car feel tighter when you drive it. You really notice the lack of flexing of the body between the roll cage and the windshield pillars, for instance. The lift will also give you more room above the trans and engine areas for things like oil coolers, etc.
I'd do it in a heartbeat. Get a beefy one, though.
Maybe hit up Bugzyla. He makes good stuff.
Posted: Sat Dec 05, 2009 06:33 AM
BTW 68... I've never seen a warrior beam mounted in the rear.
LOL.
I couldn't resist.
Posted: Sat Dec 05, 2009 03:27 PM
Like 57 said get a good body lift, the cheap $200 models you find most places are made from bent sheet metal and they will allow the body bolts to come loose after you bounce the car around a little. The Bugzyla lifts we build are 3" x 1.5" .065 wall rectangular tubing and will stiffen the car from body flex as well.
Seeing is believeing
www.youtube.com/watch?v=urTwwMBzowc
rgc3102
rgc3102
Posted: Sat Dec 05, 2009 05:45 PM
Thanks for the info. Looks like I will be installing the body lift. So Bugzyla, what am I looking at as far as price + shipping to california? One last thing, I appreciate the professionalism that those of us with little or no baja experience receive from the more experienced indivduals on this site. Thank You
RGC
Posted: Sat Dec 05, 2009 06:40 PM
Here is my ad, Free shipping on body lifts until December 31st. Cool
www.thesamba.com/vw/cl...?id=797452
Colesifer68
Colesifer68
Posted: Sat Dec 05, 2009 11:55 PM
hey 57,
i have no idea what your talkin about.
Grunt-0341
Grunt-0341
Posted: Tue Dec 08, 2009 03:11 AM
Wow! Shocked After looking at the you tube video, I sure wont be buying any junk like that when I finally get a bug.
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Posted: Tue Dec 08, 2009 04:48 PM
Colesifer68 wrote:
hey 57,
RGC3102 said...Just installed the new warrior beam went, 6 inches wider with 10 inch coil over towers. Wow! didnt know the shock towers wold be so tall! Will be using a one piece front end. Will I need to go with a body lift to have enough clearence? Thanks
jon6.0 wrote..Trim the front end to fit.
you wrote...i dont think he was talking about the front end
57baja wrote...BTW 68... I've never seen a warrior beam mounted in the rear.
LOL.
I couldn't resist.
then you wrote...hey 57,
All in good fun. Laughing Cool
24 Kreed 20777 3" Body Lift, Class 11...
 Mon Apr 18, 2016 04:44 PM
Front End question
12 ButchW 5880 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts VW Volkswagen & Baja Bug General Discussion body lift 2 elryano 2040 Re: body lift
 Thu Apr 12, 2012 09:58 PM
elryano View latest post
No new posts VW Volkswagen & Baja Bug General Discussion body lift 1 elryano 1764 Re: body lift
 Thu Apr 12, 2012 02:21 AM
No new posts VW Volkswagen & Baja Bug General Discussion Super Beetle lift kit 5 ghettodish 7357 Super Beetle lift kit
 Sun Mar 27, 2011 12:18 AM
ghettodish View latest post
