Visitors: 157
Total: 157
32: Event Calendar
44: Event Calendar
154: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- progress of my longtravel bug
baja62
baja62
Post Post subject: progress of my longtravel bug
Posted: Sat Nov 21, 2009 07:11 AM
let me know what you guys think and what i can do to improve it /AS YOU CRAWL A SLOW SPEED ON A TRAIL ,I HOVER PAST YOU LIKE LIGHTING!!! Shocked
the front
another
the side
the rear
the motor
allmost done so, let me know what you guys think!!! Shocked
longtravel
Posted: Sat Nov 21, 2009 08:40 PM
Definetly need 5 X 5s in the rear to make up for the width of the front end!
Posted: Mon Nov 23, 2009 12:17 PM
Yes, You look to be running stock rear arms on the car. Need to get some 3x3 arms on it or bigger...I'm sure that is in your plan anyway.
Colesifer68
Colesifer68
Posted: Thu Nov 26, 2009 12:28 AM
at least i hope thats his plan...would be a waste to do all that to the front end and nothing to the back...but well see.
some 5x5s would make that car sick as hell. good luck...your off to a killer start...keep it up
Post Post subject: Re: progress of my longtravel bug
Posted: Thu Nov 26, 2009 06:09 PM
[quote="baja62"]let me know what you guys think and what i can do to improve it /AS YOU CRAWL A SLOW SPEED ON A TRAIL ,I HOVER PAST YOU LIKE LIGHTING!!! Shocked
That explains the lack of an engine in the conventional place. Its a mid engine hover Baja. Nice job how long before the rear suspension matches the front? Once the rear suspension mstches the front you can prove how a good suspension is faster than a larger engine.
jon6.0
jon6.0
Posted: Sat Nov 28, 2009 04:50 AM
Off to a good start! I don't see any limiting straps? How much travel in the front? Rear?
baja62
baja62
Posted: Sat Nov 28, 2009 08:39 AM
about 20in in the front or more and the rear i'm not so sure about, i am going 3x3's in the rear with the same shocks that i have in the front. Shocked
longtravel
jon6.0
jon6.0
Posted: Sat Nov 28, 2009 08:47 AM
Are you doing the 3x3's because you don't want to move the engine rearward? I would think 5x5's would be a better match for you if you are willing to move the engine/transmission.
ChuckD
ChuckD
Posted: Mon Nov 30, 2009 08:46 AM
Alright, noob question: Was that a kit or homemade?
Colesifer68
Colesifer68
Posted: Mon Nov 30, 2009 06:31 PM
if he does choose to run 5x5s, would he be able to put in a bus tranny to get the extra length he needs? i know they are longer but i dont think its that much longer.
may be somthing to think about if it would work man
Posted: Mon Nov 30, 2009 06:36 PM
I have seen it, it is not a kit, custom made.
Posted: Tue Dec 01, 2009 12:06 AM
The flanges are in about the same place as a type 1. The reason to move it back is to get less compound angle on the cv's.
Posted: Tue Dec 01, 2009 10:16 AM
Bus transaxles are wider than the stock VW IRS so your Half shals are shorter with a Bus Transaxle. With shorter half shafts you get less wheel travel do to the incress of CV angles. That is why you go to 3x3 arms etc. to incress the length of your half shafts. The longer the shaft the less the angle at the CVs for the same given amount of wheel travel.
Crash
Crash
Posted: Tue Dec 01, 2009 06:26 PM
You don't have to move the transmission with 5x5's
Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
No new posts Projects and Builds 1966 Baja In Progress 9 Tyler 5241 1966 Baja In Progress
 Mon Feb 04, 2013 02:46 PM
No new posts Projects and Builds Bajaghia progress at ProSeatz by Bajawarrior 6 bajawarrior 3557 Re: Bajaghia progress ...
 Mon Oct 25, 2010 04:52 AM
Rybob View latest post
No new posts VW Volkswagen & Baja Bug General Discussion progress report on proseatz car- 2 Brettucks 1821 progress report on pro...
 Mon Feb 08, 2010 05:34 AM
Brettucks View latest post
No new posts Projects and Builds JWHracing's roof rack (in progress) 14 JWHracing 12255 JWHracing's roof rack ...
 Mon Apr 13, 2009 05:22 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Progress on ProSeatz by Bajawarrior 6 bajawarrior 3525 Re: Progress on ProSea...
 Tue Nov 11, 2008 02:35 AM
MOCRAWLER417 View latest post
