Latest: Nrd123
Overall: 3578
Visitors: 124
Total: 124
01: Pictures
08: Event Calendar
16: Links
22: Event Calendar
38: Event Calendar
46: Home
58: My Account
59: Event Calendar
60: Event Calendar
61: Pictures
62: Pictures
98: Links
101: Event Calendar
117: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Anyone an expert on fire extinguishers?
chickenpants
chickenpants
Post Post subject: Anyone an expert on fire extinguishers?
Posted: Sun Nov 15, 2009 10:58 PM
I have a 5lb Amerex ABC with no bracket and a 2.5lb Kidde BC with a plastic vehicle bracket.
I'm thinking neither is suitable and I should go find a new 2.5lb ABC with an all metal vehicle bracket.
Is there a good local source? And, where is a sensible place to mount it in a no roll cage baja?
Thanks!
Stephen\r\nChandler, Az
Posted: Mon Nov 16, 2009 05:26 PM
I would probably mount it on the floor in front of the driver's seat. That way you can grab it on the way out, and it should be below the plane of the seat bottom.
As far as where to buy, I would think the plastic bracket will be ok inside the car. I bough an expensive all metal bracket that mounts to the cage.
1915cc_Street_Rail
1915cc_Street_Rail
Post Post subject: Re: Anyone an expert on fire extinguishers?
Posted: Thu Nov 19, 2009 01:10 PM
The most important thing to remember about fire extinguishers is to use them on yourself and/or your passengers first, then worry about the vehicle after all the people are extinguished. That being said you can never have too much fire extinguisher. I'd rig up a mount for the 5lbs ABC somehow if it were up to me.
Chenowth sand rail / 1973 Squareback / 1971 Bus / 2011 Jetta / 2011 Jetta SportWagen
No new posts VW Volkswagen & Baja Bug General Discussion Vw baja + camaro= fire
Bad accident
6 Johnw999 3260 Vw baja + camaro= fire
 Thu Apr 26, 2012 12:15 AM
Pointvirus View latest post
No new posts VW Volkswagen & Baja Bug General Discussion National Forest and BLM fire restrictions 0 perrib 1443 National Forest and BL...
 Tue May 10, 2011 02:08 AM
No new posts VW Volkswagen & Baja Bug General Discussion Please Help I need a carb expert
Help Help Help
3 Ejbbal21 1949 Please Help I need a c...
 Thu Feb 25, 2010 06:57 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Electrical Fire! 9 Preston 3902 Re: Electrical Fire!
 Fri Jul 25, 2008 03:04 AM
Preston View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Electrical Fire Update (With Pics) 3 Preston 1482 Re: Electrical Fire Up...
 Mon Jul 14, 2008 11:21 PM
ditch68 View latest post
