Latest: jor_dang420
Overall: 3597
Visitors: 84
Total: 84
07: My Account
14: My Account
17: Pictures
23: Event Calendar
28: Pictures
32: Contact Admin
38: Pictures
40: Event Calendar
50: Event Calendar
59: Pictures
65: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- bent front torson leafs
1969Type1BAJA
1969Type1BAJA
Post Post subject: bent front torson leafs
Posted: Sun Nov 15, 2009 08:01 PM
so i pulled off my front trailing arms on my ball joint front end passenger side came off fine. But when u pulled off the driver side the bars are bent to the front is that normal just want to know thanks
Post Post subject: Re: bent front torson leafs
Posted: Sun Nov 15, 2009 10:52 PM
I've seen some that way, I would not worry about it.
1969Type1BAJA
1969Type1BAJA
Posted: Sun Nov 15, 2009 10:57 PM
ok i will psot some pics of my baja soon
Posted: Sun Nov 15, 2009 11:12 PM
It could be the beam bent on one side and just gining the illusion of the torsions being bent.
1969Type1BAJA
1969Type1BAJA
Posted: Mon Nov 16, 2009 12:21 AM
i hope not im the second owner of the bug and i never hit any thing and it drove fine before i went baja but if its bent the time for A arms to be welded up
Posted: Mon Nov 16, 2009 05:29 PM
That would be an extreme repair for an inexpensive beam replacement.
Posted: Mon Nov 16, 2009 07:54 PM
If you have not noticed any handling issues or tire wear it is not even bent enough to worry about.
No new posts VW Volkswagen & Baja Bug General Discussion Go Full Coilover With Through Rods or Just Use Stiffer Leafs 2 Trevabooooy 1973 Re: Go Full Coilover W...
 Fri Jun 02, 2017 02:18 PM
No new posts VW Volkswagen & Baja Bug General Discussion Bent beam 1 cperry2704 1702 Bent beam
 Tue May 30, 2017 03:38 AM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2365 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 7796 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3558 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
