Visitors: 122
Total: 122
08: Event Calendar
42: Home
80: Pictures
86: Event Calendar
122: Event Calendar
1 2 3 ... 22 23 24 ... 103 104 105
Posted: Wed Oct 28, 2009 12:25 AM
Installed rear view mirror.
chickenpants
chickenpants
Posted: Wed Oct 28, 2009 01:07 AM
Is that a stock mirror? if so, where'd you get it. Mine is embarrassing!
And I did nothing to mine today, first time in many months. It was wonderful to get to drive it finally.
Stephen\r\nChandler, Az
Posted: Wed Oct 28, 2009 01:13 AM
Sorry. I don't know where it came from. It has been hanging around for about 15 years. It has a curved mount for tubing that has two places for screws. I drilled and tapped the top tube. It is all steel so it is old. I would like to have had a few more of them.
Posted: Wed Oct 28, 2009 10:32 PM
I bought limit straps today for all 4 corners. I'll be putting them on tonight after I get off of work.
baja17
baja17
Posted: Fri Oct 30, 2009 06:42 PM
put the new window in that i got from perri, thanks,
Posted: Fri Oct 30, 2009 07:03 PM
Your welcome. baja 17
Blake22211
Blake22211
Posted: Sun Nov 01, 2009 04:31 AM
Put new Racetrim seats in =D
Straights are for fast cars...Turns are for fast drivers...
My Garage Link!
siacs
siacs
Posted: Sun Nov 01, 2009 05:40 AM
Finally changed over to a alternator Cool Bright Lights Cool
Posted: Mon Nov 02, 2009 01:00 AM
Took mine to the car wash Saturday. It thanked me by letting the acc pump rod clip and spring get pushed off. (Porsche gets over $20 for the clip, spring and washer.) I made it a few hundred feet from the car wash to Warner Rd. before it stalled and would not start. Use a piece of wire to keep it on. I learned how important the accelerator pump is on a Zenith carb.
Posted: Mon Nov 02, 2009 06:35 AM
I did some dash layout and cut out the opening for the speedo. Also welded on the rear fenders.
Posted: Mon Nov 02, 2009 06:51 AM
No pretty pictures? Shocked
Posted: Tue Nov 03, 2009 06:40 AM
Put the new 1 piece front end (scored for free) on mine, put some seats in "Willy Style" my Youngest sons, and worked on seat mounts for "Project II" my other sons baja. Oh also helped Caversmoon get his closer to driving again.
Posted: Tue Nov 03, 2009 09:33 PM
I ordered a pair of 2.0 Fox's today for for the rear of my car. Should be here tomorrow or thursday. Smile
Posted: Wed Nov 04, 2009 01:40 AM
I found an oil leak in the newest hose on the engine. It will be a good time to install the oil thermostat i bought from Dougs.
nateinoc
nateinoc
Posted: Wed Nov 04, 2009 05:04 AM
today I got home and cleaned out the baja. took out the seats and harnesses. took out the shocks in the rear and organized what was what and where it should go. tomorrow I'm going to cut the cage apart and take it out. the reason for that is that the guy that I bought it from did the welding and he did it with a crappy 110 mig welder. the welds are all bobble gum and pieces of wire not even melted. the guy used odds and ends for material,he tried to use a stop sign post for part of the shock mounts and pieces of exhaust pipe for tubing in the rear of the cage. least to say is that it was and is wrong,but not according to him!!! after that take it to the shop and start tubing in a cage and new front end.
4 Admin_AzBaja 6194 Baja Bugs on Wiki need...
285 MusicManiac 230094 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 421 Re: Had to go play in ...
0 Northmountainauto 1013 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2917 Baja hiding in Chandle...
