Visitors: 112
Total: 112
22: Event Calendar
47: Event Calendar
51: Home
60: Event Calendar
75: Home
82: Event Calendar
89: Event Calendar
95: Event Calendar
97: Event Calendar
100: Pictures
108: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- desert video
desert video
saltyslug
saltyslug
Post Post subject: Re: desert video
Posted: Thu Oct 05, 2006 04:26 PM
AZteacher they usually run the toyota corolla engines. high revving, good hp, RELIABLE and smooth. these engine you can usually stand on the gas and not worry about much. once you start running big HP, you gotta be careful the throttle. too much hp on curves and bumps and jumps isn't always a good thing.
I am wondering what they do about the direction of the engines rotation on the honda engines. they rotate backwards. so do they just change the cams out or anyone here know??
VIN70
VIN70
Posted: Fri Oct 06, 2006 02:22 AM
i think they change the trans.
Posted: Fri Oct 06, 2006 07:27 AM
Most of the race cars use a medola(sp?) trans that are the best out there.
bajasam96
bajasam96
Posted: Fri Oct 06, 2006 07:47 AM
Mendola= BIG$$$$$$$$$$
saltyslug
saltyslug
Posted: Fri Oct 06, 2006 04:58 PM
so are they running the mendolas backwards? I heard you only had to change the cams to make the engine rotate clockwise. I am sure crower can reverse the cams for ya=$$$. it seems that would be easier than making the tranny built to run backwards??
a gsr engine would be sweet to put in a baja NA. 8000 rpm redline. I also heard a rumor that the j spec STI 7series engine can rev to 9200 rpm.
don't tell me to get a rotary either, cause I already got one im my super sleeper.
Posted: Fri Oct 06, 2006 07:04 PM
it's not that simple as a cam regrind to reverse an engine, You have things like the oil pump running backwards, water pumps not built to flow water backwards even if you revers the belts, timeing chains/belts/gears might not run backwards some have idlers that only work one way etc. etc.
Not as simple as most people think.
No new posts Projects and Builds Vintage race junk donated it's parts 4 my desert toy.
Rebuilt this thread after I sold the frame
38 Azdrtdog 21084 Vintage race junk dona...
 Fri Apr 14, 2017 02:13 AM
No new posts New Members New Member who loves the desert
69' Baja Bug
3 spheromike 3005 New Member who loves t...
 Mon Sep 08, 2014 06:09 AM
No new posts VW Volkswagen & Baja Bug General Discussion PepeAzul Class 11 Baja 500 Video 11 wideopenmotorsports 3908 Re: PepeAzul Class 11 ...
 Mon Jul 21, 2014 04:06 AM
No new posts New Members An Arizona Desert Rat 1 t.goodman58 1981 An Arizona Desert Rat
 Thu Jan 23, 2014 03:13 AM
No new posts VW Volkswagen & Baja Bug General Discussion Alyssa's Uncle Ben's Rice Video Contest Announcement
Need your Help, Please Vote!
8 AzBaja Alyssa 6290 Alyssa's Uncle Ben's R...
 Wed Oct 23, 2013 09:22 AM
