Latest: Milkmanbryan
Overall: 3583
Visitors: 139
Total: 139
13: Home
20: Pictures
52: Pictures
57: Pictures
66: My Account
82: Pictures
90: Home
116: Pictures
123: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- KG steering shaft in Bug?
Different.Drummer
Different.Drummer
Post Post subject: KG steering shaft in Bug?
Posted: Tue Oct 13, 2009 05:56 AM
When I got my Baja there was slop in the steering wheel to steering shaft connection.
Grant steering wheel with their adapter. I figured the PO had screwed up and put the wrong adapter on. I bought a new adapter kit and have the same problem. Adapter will go onto the splined end of the shaft but is not a tight fit.
Called Grant for assistance and talked to Joey in Tech. We double checked both adapter part #'s and both are correct for my 1972 type1.
He said there was 3 generations of VW Bug shafts.
First: Early splined with no taper and the largest diameter which my adapters would not go on.
Second: What my 1972 should have. Splined with no taper Middle of the road in diameter.
Third: Beginning around 1973 a splined WITH taper that my adapter would just spin on with no engagement of splines.
He also said there was an odd shaft used in the KG that was just slightly smaller than the 2nd generation shaft that my adapters would go on but be sloppy. His feeling is my shaft was changed at sometime to one of these. ( They never made adapters for the KG shaft because of little demand )
Anyone had any similar experiences putting an aftermarket steering wheel in your cars?
My shaft sure looks original! I have been doing a lot of work on this car and have found nothing but original equipment.
I am hoping I can find a simple fix for this. I really would like to get this together and not be searching fr a new steering shaft.
Thanks for any suggestions.
" If a man does not keep pace with his companions,
perhaps it is because he hears a different drummer.
Let him step to the music he hears,
however measured or far away "
- Thoreau
Posted: Tue Oct 13, 2009 09:39 AM
Mighty Putty...
Different.Drummer
Different.Drummer
Post Post subject: Re: KG steering shaft in Bug?
Posted: Tue Oct 13, 2009 01:07 PM
Mighty Putty...
Not sure if you are serious and I am not familiar with mighty putty.
However, if it sets up hard I am guessing that I would have trouble getting the steering wheel off if I had to. If it remains soft the steering wheel could still work on the splined shaft. Joey at Grant warned me that the die cast adapter would eventually fail if allowed to work on the spline. Mating surface to the shaft would strip out.
I am considering wrapping the spline with some thin metal shim stock if I can find some. I am not sure where to look for it. Preferably brass. It wouldn't take much.
I am trying to research what year range of shaft I can use.
Thanks for the reply
- Thoreau
Posted: Tue Oct 13, 2009 04:09 PM
Just replace the steering shaft if there is any doubt. I knew about the 3 generations of shafts in a bug, but I never knew there was an oddball in a ghi, But I have only owned 2 ghias and God knows how many beetles, maybe 250 or so in the last 20 years. Shocked
Posted: Tue Oct 13, 2009 05:42 PM
You have to use mighty Putty 3 or 3 HD and is is only good if you never turn the steering. Just find a shaft to fit the adapter.
Posted: Wed Oct 14, 2009 12:55 AM
Mighty Putty
www.youtube.com/watch?v=Rb2bMdH1iPY
It's a joke...
Different.Drummer
Different.Drummer
Posted: Wed Oct 14, 2009 02:39 AM
Mighty Putty
It's a joke...
Got Me!! Embarassed
Guess I am really out of touch. Never heard of the stuff. Then again I don't watch much TV. I figured it was like JB Weld or something. Laughing
- Thoreau
kyle_pc_75
kyle_pc_75
Posted: Wed Oct 14, 2009 02:43 AM
Sorry, what's the KG?
Kyle
Posted: Wed Oct 14, 2009 06:25 AM
Karman Ghia
No new posts Projects and Builds Cheap DIY electric power steering
16 Azdrtdog 8579 Cheap DIY electric pow...
 Fri Nov 06, 2015 01:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion looking for shocks and steering dampner 2 Rigger 1606 looking for shocks and...
 Tue May 13, 2014 12:30 PM
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 8601 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Parts 0 catchbats 1354 Steering Box Parts
 Fri Feb 05, 2010 02:35 AM
catchbats View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Puttin in a baja steering column 5 WaBaja 2496 Re: Puttin in a baja s...
 Sun Dec 07, 2008 12:35 AM
WaBaja View latest post
