Visitors: 142
Total: 142
03: Event Calendar
33: Pictures
38: Event Calendar
45: Event Calendar
53: Event Calendar
60: Event Calendar
61: Event Calendar
73: Event Calendar
116: Event Calendar
125: Pictures
140: Pictures
141: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Looking for easy/cheap seat swap
bajagill
bajagill
Post Post subject: Looking for easy/cheap seat swap
Posted: Tue Sep 29, 2009 09:19 AM
I'm looking to replace the seats in my baja and was wondering what there might be out there that would be really close to a straight bolt-in or maybe something that's pretty easy to switch over to the bug seat bases. Due to lack of funds right now I'm mainly looking at wrecks and any throw-aways like derby car builders always have laying around. Also any types of cars/trucks whose seats I should just stay away from? I don't want end up riding around looking like one of those punk "gangstas" or some poor ol' grandma looking under the wheel and over the dash. lol Something I can sawzall and/or drill and bolt preferably, I'm out of acetylene and access to a wire feed is pretty spotty w/ my schedule.
Post Post subject: Re: Looking for easy/cheap seat swap
Posted: Tue Sep 29, 2009 04:08 PM
I have put in many seats from Rabbit seats up to Dodge PU bucket seats in Beetles. The problem is modern seats do not have the tall seat base a VW T-1 has. I suppose a base could be bolted together and diagonally braced until you had time to weld it.
bajagill
bajagill
Posted: Wed Sep 30, 2009 09:04 AM
I've not had the opportunity to tear into any VW seats so far....could a person take the actual seat off the tall base and replace it w/ something close? Or, is that more trouble than it's worth?
Posted: Wed Sep 30, 2009 09:37 AM
Look into a PT cruzer. My moms PT GT Turbo has some nice seats and the seats sit up high too.
Not sure how wide the seats are but I do think a set will fit in a bug and there are tons of PT's out now.
Posted: Wed Sep 30, 2009 11:19 AM
That is the easiest way to do it. It works well for later model VW seat swaps. Unless it is the triangulated seat track from the later pans you still have the weak seat tracks that can pull out
in an accident. It also requires welding which Bajagill is trying to avoid.
Posted: Wed Sep 30, 2009 12:38 PM
99 & up cavalier seats. We have put 5 or 6 sets in bajas and they work great. They are the right width, comfy, and are easy to mount. All you need are 2 inch spacers, we use the empi shock bosses that cost $1 each. If you watch craigslist you can pick up a pair of seats in great shape for $75 to $125
bajagill
bajagill
Posted: Sat Oct 03, 2009 09:22 AM
thanks guys, appreciate the input! I was also remembering some of the old Ford van seats that had the tall base on them. The seats weren't the greatest but it would still be a step up from what's in there now.
No new posts Projects and Builds Toyota 3tc swap
Baja bug toyota swap
15 Sandrailbuilder 10533 Re: Toyota 3tc swap
 Thu Jun 06, 2019 01:45 AM
6 AZOffroadSwapmeet 4367 AZ Off-Road Swap Meet
 Fri Dec 09, 2016 03:37 PM
No new posts Projects and Builds Cheap DIY electric power steering
16 Azdrtdog 10301 Cheap DIY electric pow...
 Fri Nov 06, 2015 02:07 AM
5 bajabuggy69 5376 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VW TDI Engine swap? 8 Grunt-0341 6957 VW TDI Engine swap?
 Thu May 02, 2013 01:06 PM
blg4351 View latest post
