Visitors: 103
Total: 103
07: Pictures
12: Event Calendar
17: Pictures
18: Event Calendar
26: Event Calendar
39: Event Calendar
48: Event Calendar
81: Event Calendar
89: Event Calendar
96: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- HELP! AzBaja's Baja fix Day!
Post Post subject: HELP! AzBaja's Baja fix Day!
Posted: Tue Sep 08, 2009 10:15 AM
Saturday, September 26, 2009….8:00am - 2pm or later if need be...
ok, I will need some help, If we (Me and the wife) plan on driving the Baja to chircos this year. As you know I work nights and have odd hours plus I have 2 kids so I no longer have the time to work on the baja...
Things that I need to get done are
1. Replace the clutch
2. New CV boots and repack all CV's
3. Replace all broken Zip ties.
4. New Brake pads on the rear then bleed the brakes.
5. new wiper blades
6. Fix review mirror on drivers door
7. Oil Change
8. file notch out of starter (Needs to be done to work with 2.3)
9. fix bad wire to lights on front, replace side light bulb
10. other little things not listed...
Most of this is real qucik stuff it's just trying to get it done when I have zero time to my self anymore.
The wife and I were able to set aside one day
Saturday, September 26, 2009…. 8:00am
to get this all done. Any help would be great!!! I mostly need the helps with the clutch, it can be done in under 30 minutes with 2 people. CV's about an hour.
I will have food from pizza, soda, grilled hambergers etc. We can also work on other Baja's too once we get done with mine Embarassed . I'm an electrical person among other things...
Thanks and hope to see some one show up at the house.
926 W. Los Lagos Vista Ave.
Mesa, Arizona
(480)899-1141
baja17
baja17
Posted: Tue Sep 08, 2009 04:55 PM
i will be there,az long as you an help me with some wiring on my ignition okedoky
caversmoon
caversmoon
Posted: Tue Sep 08, 2009 11:24 PM
I need to check with the wife but I think I can come
Post Post subject: Re: HELP! AzBaja's Baja fix Day!
Posted: Wed Sep 09, 2009 05:12 AM
not a problem.
Posted: Wed Sep 09, 2009 05:13 AM
Thanks the more hands the faster things get done.
Posted: Wed Sep 09, 2009 06:27 AM
i wish i could help yah man but im going fishing that weekend
Posted: Wed Sep 09, 2009 02:18 PM
If its at all possible I will be there.
Posted: Mon Sep 14, 2009 09:46 AM
I was think if people would like to show up before 8am, like 7am...this would be fine too as we can get stuff done before the heat sets in.
I also need to get my old electric fan motor pressed out and replaced with the the new electric motor...I'm thinking Bugzilla can handle this one....If he has a press etc.
Posted: Tue Sep 15, 2009 02:51 AM
If I left now... I might make it by the 26th. But we 'd have to have a repair day for the "Cow Bug" & for my old tired bones too... Laughing
Wish I could make it, sounds like a good fun day...
Brettucks
Brettucks
Posted: Fri Sep 18, 2009 09:49 PM
I will try to show up- now you know Im not a bug genius, the small stuff sounds easy though... Im just looking to see some things come apart before I screw up my own and ask some ???'s
-Brett
Posted: Sat Sep 19, 2009 02:25 AM
-Brett
This is all basic wrench turning stuff...My car is more Ford,GM & Plymouth than VW... Rolling Eyes
Mostly heavy lifting engine in and out etc.
bajagill
bajagill
Posted: Tue Sep 22, 2009 08:39 AM
I wish I could come help too...and learn! I just traded for a '75 baja w/ the Ford 2.3 already installed but there's quite a bit of "hackage" to redo. i.e. - throttle cable extension that actually works throught the entire stroke w/out rubbing on the exhaust, headlights that work, carb rebuild, new gaskets for the tin, fill in the 2 ft hole some goob cut right in front of the engine( at least the "builder" didn't just leave the engine hanging off the original mounts only), get the electric fan mounted to the radiator, plumb in a heater core if I can still find it Sad , THEN.....lol!! I'm sure some of you have already been there...Too bad that E. Oregon is so far from Mesa!
Posted: Thu Sep 24, 2009 03:31 PM
Clutch and other parts showed up yesterday!!!!
Posted: Sat Sep 26, 2009 02:00 AM
We are of to Wal-Mart to get the tent for tomarrow. I need to get the engine host rolled out in the morrining. Need to clear all the baby stuff out of the way 1st.
baja17
baja17
Posted: Sat Sep 26, 2009 06:26 PM
sorry i wont be able to make it, i dont have the gas or money to drive that far
5 Admin_AzBaja 7140 Baja Bugs on Wiki need...
29 AzBaja 32282 Re: "AzBaja Supporting...
 Mon Mar 09, 2009 07:32 PM
cyberjaw4 View latest post
1568 mufasavnvmc 1013137 Re: what did you do to...
285 MusicManiac 244609 Re: Baja sightings
32 AzBaja 35380 Get the www.AzBaja.com...
 Fri Feb 03, 2012 10:36 PM
1966baja View latest post
