Latest: ddbug11
Overall: 3596
Visitors: 108
Total: 108
01: My Account
18: Event Calendar
20: Pictures
62: Contact Admin
65: Event Calendar
67: Event Calendar
90: Event Calendar
105: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 12 gauge
12 gauge
Post Post subject: 12 gauge
Posted: Thu Sep 17, 2009 02:13 AM
We all like guns but,,,, Heres a question for all,,Where are your fuses located? In the trunk area? Where is your battery located? What about the wire between the fuse and the battery how is that protected,,What if it had a short in between.? Your fuses should be as close as possable to the battery keeping the wire as short as possable,from the fuse to the battery,, How many have a fuse in the ign switch hot wire from the battery;Is it the proper gauge? Did you use the right gauge for that amp you just hooked up? How about them offroad lights? Rolling Eyes
Just a thought!
Post Post subject: Re: 12 gauge
Posted: Thu Sep 17, 2009 03:27 AM
too much coffee there jimbo....? Shocked
or did you have a fire your not telling us....?
Posted: Thu Sep 17, 2009 03:38 AM
yes rob,,,coffee,,thats it,, none of the above i,m going to finish installing my stereo this weekend my amp came in today,,just somthing i was think,n about,
madman74
madman74
Posted: Thu Sep 17, 2009 04:14 AM
Thats why I run 00 welding cable for eveything! sure is hard to run up to the dome light though Shocked
Oops it broke!
Posted: Thu Sep 17, 2009 05:06 AM
That figures MM, You redneck! Laughing
Posted: Fri Sep 18, 2009 05:11 AM
Don't know how to copy the link, but if you go to the Outfront Motorsports website and under the Home Page section there is a tab for building cars. They have a great bit on basic wiring. even can help the novice calculate amps to determine the wire size. James, you definately bring up a good point. Using the wrong size wire may get you by for a while, but eventually you will have trouble. I need to rewire quite a bit of the sand rail. Didn't have the fuse at the starter. Damn near started a fire. By the time I realized the problem I had a big wad of melted wire!
Posted: Fri Sep 18, 2009 06:02 AM
yes rob,,,coffee,,thats it,, none of the above i,m going to finish installing my sterio this weekend my amp came in today,,just somthing i was think,n about,
Installing a stereo and STILL hasnt got the car through emissions as far as I know, there is a guy with his priorities in order!!! Shocked Shocked Mr. Green
Sorry Jim, Had to give you a bad time. Laughing Laughing Laughing
Posted: Fri Sep 18, 2009 01:02 PM
OK,,I HAVE THAT COMING!
Posted: Fri Sep 18, 2009 02:12 PM
But when it does pass,,It will be 'so ready 'to drive!
Posted: Fri Sep 18, 2009 02:33 PM
Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Posted: Sat Sep 19, 2009 01:57 AM
i was going to razz you about that head board light bar, but i thought better of it...... Mr. Green
Posted: Sat Sep 19, 2009 03:29 AM
Razz
Posted: Sat Sep 19, 2009 03:43 AM
The only reason its on there rob is because you dont like it,,When its on the road i,m going to park it in front of your house! Laughing
Posted: Sat Sep 19, 2009 03:46 AM
By the way,,its the front of what is going to be a roof rack
Posted: Sat Sep 19, 2009 03:52 AM
hoa will have it towed for non op.....ha Laughing
No new posts VW Volkswagen & Baja Bug General Discussion rpm gauge installation 7 danjones333 8876 rpm gauge installation
 Sun Jun 21, 2009 08:01 PM
No new posts VW Volkswagen & Baja Bug General Discussion Gas Gauge Alternative 2 squirrel 1763 Re: Gas Gauge Alternat...
 Thu Apr 19, 2007 02:13 AM
No new posts VW Volkswagen & Baja Bug General Discussion fuel gauge messed up 6 bajajon 3270 Re: fuel gauge messed ...
 Thu May 11, 2006 04:58 PM
69bapbaja View latest post
