Visitors: 300
Total: 300
04: Home
11: Home
20: Home
39: Contact Admin
58: Pictures
59: Pictures
60: Pictures
61: Pictures
64: Event Calendar
74: My Account
75: Event Calendar
78: Pictures
96: Event Calendar
104: Home
148: Pictures
149: Pictures
151: Pictures
154: Baja Forums
161: Pictures
164: Baja Forums
166: Event Calendar
168: Event Calendar
169: Event Calendar
172: Event Calendar
174: Event Calendar
193: Pictures
197: AMAZON.com
198: AMAZON.com
202: Baja Forums
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: Baja Forums
210: Baja Forums
211: Groups
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
215: Event Calendar
216: Baja Forums
217: Baja Forums
218: Baja Forums
219: Baja Forums
220: Baja Forums
221: AMAZON.com
222: Baja Forums
224: Baja Forums
225: AMAZON.com
226: Baja Forums
227: AMAZON.com
228: Event Calendar
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: Baja Forums
240: Baja Forums
241: AMAZON.com
242: Baja Forums
243: Baja Forums
244: Baja Forums
245: Baja Forums
246: Baja Forums
247: Baja Forums
248: Baja Forums
249: Baja Forums
250: Baja Forums
251: Baja Forums
252: Baja Forums
253: Baja Forums
254: Baja Forums
255: AMAZON.com
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: Pictures
260: AMAZON.com
261: Baja Forums
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
268: Baja Forums
269: AMAZON.com
270: AMAZON.com
271: AMAZON.com
272: AMAZON.com
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: AMAZON.com
277: AMAZON.com
278: Baja Forums
279: AMAZON.com
280: AMAZON.com
281: AMAZON.com
282: AMAZON.com
283: AMAZON.com
284: Baja Forums
285: AMAZON.com
286: AMAZON.com
287: Baja Forums
288: AMAZON.com
289: Baja Forums
290: AMAZON.com
291: AMAZON.com
292: AMAZON.com
293: Baja Forums
294: AMAZON.com
295: Baja Forums
296: Baja Forums
297: AMAZON.com
298: AMAZON.com
299: AMAZON.com
300: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- California
California
1 2 3 4
elryano
elryano
Post Post subject: Re: California
Posted: Fri Jul 28, 2006 09:20 PM
try going up 1 spline on the torsion bars in the rear will bring you up about two inches i wouldent cut off the stops becuase that would allow the springplates to drop lower than the type 1 joints can handle
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 09:23 PM
so if i get type 2 CV's then i can grind the stops off? and then i can get off road torsion bars and get some more lift...
elryano
elryano
Posted: Fri Jul 28, 2006 09:25 PM
if you wanna go that far id go with 930s
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 09:28 PM
well right now my rear right wheel rubs on my fender when i hit any kind of bump. the guy i bought it from put 31's on there. they are some beefy tires. and there is only 1/2" between the spring plate and the stop when the vw is sitting on the ground not moving. so is 1 notch on the spline going to make it so that i am right on the stop?
elryano
elryano
Posted: Fri Jul 28, 2006 09:45 PM
it might but it will ride better and you will have more ground clearance
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 10:15 PM
to take the drive axles off it uses a 12pt 8mm socket right?
cperry2704
cperry2704
Posted: Fri Jul 28, 2006 11:38 PM
im in carlsbad, ca right south of the military base
72BajaBen
72BajaBen
Posted: Sat Jul 29, 2006 10:49 AM
awesome man...that is right down the street....=]
Posted: Sat Jul 29, 2006 05:19 PM
About there, you may have to compress them to get them in. This is where it gets tricky.
More of a bit than a socket. Why do you need them out?
72BajaBen
72BajaBen
Posted: Sun Jul 30, 2006 06:29 PM
i coldnt get the swing arm out fo the way, i had to take the axle off and it made it a whole lot easier. Im going to adjust them again today. Do anyone know how to adjust the front. or do i need to get front adjusters and weld them in?
Posted: Sun Jul 30, 2006 09:03 PM
cut, turn , and add adjusters to the front
elryano
elryano
Posted: Mon Jul 31, 2006 03:44 AM
you can also just cut and twist the beam dont turn the beam more than a quaeter inch top and bottom
Galvin
Galvin
Posted: Sun Oct 01, 2006 03:17 AM
Huntington Beach !!!
Posted: Sun Oct 01, 2006 04:36 AM
also in the front on the link pin beam you can remove one split stack of springs and replace it with a solid spring. but only do one of the split packs, both is some times too stiff. You will need another link pin beam to get the extra stacks
Dezjunky
Dezjunky
Posted: Sat Oct 21, 2006 11:49 PM
If you're still looking for people in Cali, I'm in the LA county Fairplex area.
No new posts New Members New from California 4 Zack149 2840 New from California
 Thu Oct 08, 2015 08:04 PM
No new posts Events and Get Togethers World Wide The VW Classic-Irvine, California 7 JWHracing 4517 The VW Classic-Irvine,...
 Sun Jun 23, 2013 01:32 PM
Yummi View latest post
No new posts VW Volkswagen & Baja Bug General Discussion New laws passed in the state of California... 7 JWHracing 5924 Re: New laws passed in...
 Mon Jul 30, 2012 05:02 AM
thing View latest post
No new posts We Will Host Your Club Forum here Anyone from the Bay Area, California? 4 zx10r203 4418 Anyone from the Bay Ar...
 Fri Feb 04, 2011 04:05 AM
mikehtiger View latest post
No new posts New Members Hi from foggy California 3 mikehtiger 2953 Re: Hi from foggy Cali...
 Fri Jan 21, 2011 01:45 PM
