Latest: xbluegto
Overall: 3573
Visitors: 146
Total: 146
29: Event Calendar
40: Event Calendar
74: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- NEW 2 BAJA
NEW 2 BAJA
shownuff1980
shownuff1980
Post Post subject: NEW 2 BAJA
Posted: Fri Sep 11, 2009 12:16 AM
hey guys im new 2 bajas and just was wondering if u guys could give me some helpful tips on building my 1st baja bug? like what to get first, etc.( i have a 1970 stand. with a dual port 1600)I want something that has good suspension so i could fly down desert roads, but nothin 2 crazy.
Post Post subject: Re: NEW 2 BAJA
Posted: Fri Sep 11, 2009 01:58 AM
With 4 " longer front and 3"x5" rear arms you can fly through almost anything. See my Crown King and Boulder Mountain videos on AZBAJA.com. . I only have 1" longer front and 3" longer rears but the rail is lighter than a Baja. Look at these to get an idea how rough the terrain is on the Crown king Rd..
www.youtube.com/watch?v=6qYYY7sjheI
www.youtube.com/watch?v=B5Z_lyCS3Eo
You made the right choice building the suspension first. Next for a 1600 a VW 3 rib transaxle like the one Bugzyla is selling is the next step. It restores the power the engine lost turning larger heavier tires.
Suspension seats and 5 point harness are also a first on the to do list.
Grunt-0341
Grunt-0341
Posted: Fri Sep 11, 2009 03:53 AM
Hey Perrib,
By a longer front, do you mean wider? Or have you extended the wheel base between the front and back of the car?
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Posted: Fri Sep 11, 2009 04:08 AM
I meant longer arms for more travel. But then there are also wider beams and lengthening the wheel base. Get yourself a copy of Building Bajas and Buggies. It will be your best tool.
Posted: Fri Sep 11, 2009 04:12 AM
cant help with out pics lol
Grunt-0341
Grunt-0341
Posted: Fri Sep 11, 2009 04:14 AM
Thanks Perrib ,
I got that book and How to hot rod VW engines. I just need to find the time to read them.
Grunt-0341
81mm Mortar Man
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Grunt-0341
Grunt-0341
Posted: Fri Sep 11, 2009 04:15 AM
shownuff 1980,
Welcome. It's good to have you here. I'm sorry for the post jack. Get the books and keep posting.
Grunt-0341
81mm Mortar Man
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Grunt-0341
Grunt-0341
Posted: Fri Sep 11, 2009 04:16 AM
shownuff 1980,
Grunt-0341
81mm Mortar Man
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
shownuff1980
shownuff1980
Posted: Fri Sep 11, 2009 10:50 AM
no problem, i need to get that book aswell. should i also run a higher shock tower in the front? and should i run the rear shocks up thru the body for more travel or just use the o.g. shock mounts? what r good shocks for the front and rear? and can i use the stock wheels 4 offroad tires? thanx for the help guys. more tips would be great. (what is a 3 rib transaxle out of?)
Posted: Fri Sep 11, 2009 04:29 PM
Wheelbase and wheel travel are your friends when going fast in the desert.
As far as shocks/mounts etc. The longer the stroke on the shock the more travel it can support. The longer the stroke, the longer the shock, the higher the upper mounts have to be.
I have 10" stroke fronts with custom mounts on my 6" longer beam, with 2 1/4" longer, 1" wider (2 1/2 x 1) trailing arms that is pushed forward ~5".
The rear is 3" longer and 3" wider (3x3) trailing arms and 14" stroke shocks with the upper mount built into the cage.
I have FOA rear shocks and Sway a way front coil overs.
Some people do fine with modified stock. ie..better shocks on stock size stuff. Then upgrade as time goes on.
Others go much bigger than mine...10" wider beam, 4x1.5 frt arms pushed forward ~8"; 5x5's in the rear etc.
A good build thread is on Chirco's site. Good size, not a ton of money.
www.chircoestore.com/c...icles_id=2
shownuff1980
shownuff1980
Posted: Fri Sep 11, 2009 10:14 PM
thanx. again this helps.
Posted: Sat Sep 12, 2009 04:12 PM
keep an eye out here for deals... Wink
www.thesamba.com/vw/cl....php?id=66
Posted: Sat Sep 12, 2009 09:18 PM
hey Rob, welcome back. Haven't heard from you in awhile.
sorry for the hijack.
nateinoc
nateinoc
Posted: Sun Nov 01, 2009 09:26 PM
i have a 70 also,gonna switch to king pin or link pin front end. with a 6" over beam,and longer arms. I'm gonna put 3x5 rear arms in back. what kind of cage do you have "dont" or is it custom.? I can make cage but was told easier to but a class 11 cage and build off of from there.I was told it is strong enough to tube the front from the cage and strong enough to mount the rear shocks? is it better to run coilovers all the way around? or is it alright to run coilovers in front and bypass's in rear with torsions? I want to be able to hammer threw what ever I want to.should I leave the torsions in the sus. front and rear or remove and run coilovers to hold the car up and bypass's for the travel? thanks and if I have asked something ass backward please be nice.. or let me know I'm asking the wrong ?'s
Posted: Mon Nov 02, 2009 06:54 PM
My cage started as an empi 6 pt, then got heavily modified by Bugzylla Fabrication.
4 Admin_AzBaja 5718 Baja Bugs on Wiki need...
1568 mufasavnvmc 904285 Re: what did you do to...
285 MusicManiac 219112 Re: Baja sightings
0 Northmountainauto 272 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1541 Baja hiding in Chandle...
