Latest: ecthemc
Overall: 3567
Visitors: 194
Total: 194
19: Event Calendar
102: Event Calendar
110: Event Calendar
112: Pictures
116: Pictures
154: Baja Forums
158: Baja Forums
164: Baja Forums
170: Baja Forums
173: Baja Forums
176: Baja Forums
177: Event Calendar
181: Baja Forums
184: Baja Forums
190: AMAZON.com
191: Baja Forums
193: Baja Forums
194: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- How To Lift Rear
How To Lift Rear
mistfo
mistfo
Post Post subject: How To Lift Rear
Posted: Sat Sep 30, 2006 05:35 PM
I'm interested in how to lift the rear of my 69 Baja. I've read there are longer trailing arms, however i don't understand how they can lift the Baja, unless it's just the angle. Wouldn't a longer arm position the tires more to the rear, and how do you align to transaxle after installing the longer arms? Do the spring plates have to be replaced? Also the current cv shafts won't allow any more height adjustment. Can i run a VW Bug transaxle and adapt to the longer arms?
Any help would be appreciated,
Thanks,
Mike
Post Post subject: Re: How To Lift Rear
Posted: Sat Sep 30, 2006 09:36 PM
get the baja book and it explains how to reindex your torsion bars, all you need is one or two splines...
24 Kreed 20337 3" Body Lift, Class 11...
 Mon Apr 18, 2016 04:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 2552 Re: Max angle for rear...
 Fri Jan 29, 2016 04:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 1420 Rear Rim Backspacing
 Fri Nov 06, 2015 03:13 AM
JWHracing View latest post
what do you use
4 bdrdunes 2102 Baja bug rear led ligh...
 Thu Dec 18, 2014 02:55 AM
Front End question
12 ButchW 5734 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
