Visitors: 108
Total: 108
05: Event Calendar
13: Links
21: Event Calendar
32: Event Calendar
39: Event Calendar
59: Event Calendar
72: Event Calendar
102: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- New guy with questions
azranger
azranger
Post Post subject: New guy with questions
Posted: Thu Sep 28, 2006 10:20 PM
I have always thought the Baja's looked awesome but have never really looked into getting one. I saw this 1969 fixer upper on the side of the road and got a wild hair and bought it.
My buddy who is the maintence guy at work knows them pretty well (I know very little about working on vehicles but he is a really good teacher) feels like it has a lot of potential. He wants to start with a new exhaust and tinker with the carb (if we can't get it running smooth he suggests a new webber. He has all the equipment to paint it so we will do that as well. the inside has had some work done and it has disk brakes on the front and a bus trans axle on the back. A couple of things that I like are lights on the top and what about after market AC. I will not be able to drive it to work in the summer here in AZ if I can't keep cool. I work in sales and can't show up all sweaty.
Any suggestions. Oh I paid $1200. I'm not sure if that is high or not.
thanks for any help.
KrazyKarl
KrazyKarl
Post Post subject: Re: New guy with questions
Posted: Thu Sep 28, 2006 11:59 PM
sweet, thats what im looking into buying, a fixer uper for 2k and under (canadian) but most likely will not find one Sad
KrazyKarl
KrazyKarl
Posted: Fri Sep 29, 2006 12:12 AM
after market AC brings down the power but you could do this:
my.break.com/Media/Vie...ntID=86883
thatl keep you nice and cool.
crap the sites being updated, try the link later
Say10
Say10
Posted: Fri Sep 29, 2006 03:27 AM
Good score man.
KrazyKarl
KrazyKarl
Posted: Fri Sep 29, 2006 08:37 PM
I have a question to ask others as well. The 2 green lights ( or 1 green one red for oil) in a beetle are very important for oil but I dont know what the other is for.
Im one who very rarely looks at gauges (thank god for the gas dinger in my truck). I just got inspired by that last night and was thinking If a could add a dinger to the oil light because I know i wouldnt see the green or red light even if I had it mounted on my rear view miror.
I was wondering could you replace the oil presure sensor with a oil presure gauge in the same hole? If not is it possible to add one?
also i do not have a baja yet but im tring do broden my knoledge on these cars.
Thanks
bajasam96
bajasam96
Posted: Fri Sep 29, 2006 08:44 PM
Yes you can run a pressure guage from where your sending unit was. Some run a T and use both, I just use a mechanical guage.
Posted: Fri Sep 29, 2006 09:09 PM
VDO sells a sender that will do both oil PSI and idiot light. I use that in my car. I hve a red light hooked next to the oil PSI guage on the car.
2 senders would be good too, if one went bad you always have the other as a back up.
Posted: Fri Sep 29, 2006 09:11 PM
the 3 lights I think are High Beam, Oil PSI and Gen/ALT/Busted fan Belt and then you have the "B" Bomb light in the dash for brakes.
Posted: Fri Sep 29, 2006 10:27 PM
for off road lights, get a baja light bar at Karls, or order from chirco. $30 or so. it holds 4 lights. just have to pick up some lights and wire em in. (a pair of 5" 100watt halogen spots at autozone and walmart for $30. thats what i run). then harbnoe frieght for the 55w halogen floods for the bumper or reverse lighting.
Posted: Fri Sep 29, 2006 11:50 PM
I think he was talking about the idiot lights in the spedo. Embarassed
Posted: Sat Sep 30, 2006 02:49 AM
swear he mentioned a light bar too.....
vwbill
vwbill
Posted: Sat Sep 30, 2006 03:14 AM
Years ago I heard racers wiring a relay to idiot lights and horns so they would not miss them. Might be an idea for you, but remember your horn would blow at each start up until your car is running.
William
KrazyKarl
KrazyKarl
Posted: Sat Sep 30, 2006 09:13 PM
Thanks for this info as well, but i was just tlaking about idiot lights for the oil presure, and hocking up a little dinger thing.
Arizonateacher
Arizonateacher
Posted: Tue Oct 03, 2006 06:20 AM
Nice Ride for the price. I paid $2500. for one similar and I had to put a new engine in it.
saltyslug
saltyslug
Posted: Tue Oct 03, 2006 10:50 PM
dont get a webber unless they are duals. just get a new pict or bronsol carb from someone online or local vw place. if you have a 30-31 step up to the 34 if you can, and get the adapter. out of the box they usually don't need much tuning if any. mine never did anyways. the bus tranny will give you plenty of torque for 30 inch mudders with that lil carb, LOL.
looks like you got a real alt also so thats a good thing. get a new aircleaner if you plan on doing any hard core off roading or steeeeeeep hills. that oil bath monster is heavy and full of oil. make sure you get a quality filter if you can afford it. get a small tube for the float vent tube in the center of the carby, 2-3inch should be enough.
I like hitting loggin roads doing 50+ so it gets rough at times.
I would get the BERG oil temp gauge before a oil pressure sender. if you get the pressure gauge, make sure it is the electrical sender type and not the tube. I know people have the tube, but it sucks cause you have 20 ft of oil tube in yer car and if it get a hole or cracks it will piss oil everywhere.
69 my fav year. dual spring plates and they seem tougher in 69 and 70. had a few of them. there is nothing wrong with that exhaust as long as there are no holes, rust is purty.
good luck
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 4976 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5771 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar questions 3 ghs215 2452 Tow Bar questions
 Mon Nov 16, 2015 02:45 PM
No new posts New Members New Guy Questions 6 Apoc 4226 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 8379 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
