Visitors: 245
Total: 245
04: Pictures
07: Home
14: Pictures
17: Pictures
26: My Account
28: My Account
29: My Account
30: My Account
31: My Account
58: Pictures
72: Event Calendar
73: Event Calendar
157: Baja Forums
160: Pictures
162: Baja Forums
171: Baja Forums
172: Baja Forums
173: Baja Forums
190: AMAZON.com
193: Baja Forums
196: Baja Forums
197: Baja Forums
198: Baja Forums
201: Baja Forums
202: Baja Forums
203: Baja Forums
204: AMAZON.com
205: Baja Forums
206: Baja Forums
207: Baja Forums
208: Baja Forums
209: Baja Forums
210: Pictures
211: Baja Forums
212: Baja Forums
213: AMAZON.com
214: Baja Forums
215: Event Calendar
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: Pictures
222: Event Calendar
224: Baja Forums
225: Baja Forums
226: AMAZON.com
227: Baja Forums
229: Baja Forums
230: AMAZON.com
231: Baja Forums
232: AMAZON.com
233: AMAZON.com
234: Baja Forums
235: AMAZON.com
236: Pictures
237: Baja Forums
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: Baja Forums
244: My Account
245: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- I'm Thinking of becoming a proud VW BAJA owner. one question
Grott
Grott
Post Post subject: I'm Thinking of becoming a proud VW BAJA owner. one question
Posted: Fri Aug 14, 2009 10:21 PM
When looking at buying a BAJA I realize there're may things to look at for. But one of many things I don't know is if VW's come with an optional positraction transmissions or if there is a BAJA upgrade kits you guys put on your BUGs to make them positraction; or if there is even such a thing. If you guys do install a positraction trany, how do you tell a positraction trany from a regular trany?
Posted: Sat Aug 15, 2009 12:28 AM
Direct this question to Azbaja member Donsbusbox. He is a VW transmission rebuilder. I believe most VW transmission mods are internal, and difficult to identify without opening them up for a peek. BUT I COULD BE WRONG- it's happened before once or twice. Laughing
Posted: Sat Aug 15, 2009 12:30 AM
You do not use or need locker, Posi etc. in a VW. The problem is with the light front end the car will push and make it very hard to turn. Evan with big fat tires and semi scinny tires up front like my car, it will push in a turn and in the dirt it's evan more of a problem.
Post Post subject: Re: I'm Thinking of becoming a proud VW BAJA owner. one ques
Posted: Sat Aug 15, 2009 03:23 PM
They are available but are not used for off roading. With practice the turning brake can be used as a limited slip. Quaffee makes a torgue sensing diff. but is is for on road use. If only ARB would nake an air locker for a VW transaxle then we would have something worthwhile for off roading.
Grott
Grott
Posted: Sat Aug 15, 2009 07:24 PM
So you guys are saying. One it isn't necessary and it is more a pain in the arse to drive. Two the turning brake serves the purpose better. Good to know
Posted: Sat Aug 15, 2009 09:04 PM
Yes. It is very very rare that you will have one of the back tires off the ground with all the weight on the back of the car.
If you get to a point were you loose traction in one tire you can tap the turning brake and slow it down.
5 Admin_AzBaja 6843 Baja Bugs on Wiki need...
1568 mufasavnvmc 1001002 Re: what did you do to...
285 MusicManiac 241775 Re: Baja sightings
0 Northmountainauto 1556 Shop Baja
