Latest: BlackIrish05009
Overall: 3574
Visitors: 132
Total: 132
02: Event Calendar
15: Pictures
28: Event Calendar
61: Home
94: Event Calendar
103: My Account
125: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 930 CV Boots
930 CV Boots
FLBaja
FLBaja
Post Post subject: 930 CV Boots
Posted: Sun Aug 02, 2009 01:30 AM
I dont really have any experience with these so excuse me if I am doing something really stupid but I dont inderstand how these boots are supposed to fit.
I have the 930 flanges, and I cant get the boots to fit over them. They slide into the flanges and seem to fit good like that but when the axle gets angled even a small amount they pop out. I know I must be doing something wrong, just cant figure out what that is. Any help would be greatly appreciated!
Posted: Sun Aug 02, 2009 02:39 AM
I wrapped safety wire around the flange end of all mine. Haven't had any problems. I've seen tie wraps used also.
For the axle side of the boots- many leave them alone to "float". Others tie wrap those as well.
Hope that helps.
Posted: Sun Aug 02, 2009 02:43 AM
You talking about the boot poping of the flange?
FLBaja
FLBaja
Post Post subject: Re: 930 CV Boots
Posted: Sun Aug 02, 2009 03:03 AM
I cant get the boot to wrap around the outside of the flange. To the point where I wasnt even sure it was supposed to go around the outside. It just doesnt seem like it is big enough to fit but it came with the CVs so it should be the right size.
I will try to get some pics tomorrow. Thanks for the help guys!
Posted: Sun Aug 02, 2009 04:35 PM
Get those pictures up. There are two different types of CV flange boot set-ups for 930's. One has the boots that cover the bolts, the other has the boots that leave the bolts exposed. Which type do you have?
Posted: Sun Aug 02, 2009 10:09 PM
My boots are held in by the allen head axle bolts.
Both style boots.
FLBaja
FLBaja
Posted: Mon Aug 03, 2009 02:54 AM
Here are some pics that may help.
Posted: Mon Aug 03, 2009 03:01 AM
Mine look like they have more angle than yours but it could be an illusion. I believe i set the droop at 22 degrees. Are you using 3/8 allen bolts. The heads on the allens hold them tight against the flange. I'm using Empi boots on Sway Away axles.
FLBaja
FLBaja
Posted: Mon Aug 03, 2009 03:07 AM
So what your saying is that the boot should go over the flange, correct? The problem I am having is that I cant seem to get the boot over the flange. The boot came from Lobro(?) along with the CVs and the flange if that helps.
If they are supposed to be REAL hard to get on maybe I just didnt try hard enough.
Posted: Mon Aug 03, 2009 07:03 AM
I'm not sure what the deal is, but those boots do look too small. Could they be Type 2 boots or something? Sure seems odd- mine look different and fit on the flanges no problem. If my car was here I'd post a pic for ya.
Posted: Mon Aug 03, 2009 07:20 AM
The boots could be small, I would also change your bolts to allen type. You have the set that use a socket and can give you problems once the boot is on.
If the boots do slide over the flange. Use some safty wire (not a Ziptie!!! a ziptie will pu;; the boot off when you tighten it.) and rap the safty wire around the boot. Once the wire is tight give it a 90' z bend 180' from the twist point of the wire. This will hold the boot in place.
I normaly do this 1st so the boot and flange are one unit the bolt the flang in place. if your fighting with the boot and flange at an angle you could be there all month.
Posted: Mon Aug 03, 2009 03:15 PM
i 2nd that: They don't look like 930 boots to me.
Posted: Mon Aug 03, 2009 04:07 PM
I looks like you have a street style boot. Very few ribs vers the off road type that has a bunch of ribs that will fit over your off road type CV boot flange.
This is what you should have.
FLBaja
FLBaja
Posted: Tue Aug 04, 2009 03:05 AM
OK so time to buy new boots and bolts. Before I make my order does everyone agree with this selection
930 CV Boots
CV Bolts
Posted: Tue Aug 04, 2009 04:19 AM
You can mail me those extra bolts!!! Those are the ones I use.
No new posts VW Volkswagen & Baja Bug General Discussion anyone sell good type2 or 4 cv boots around here? 1 madman74 1525 Re: anyone sell good t...
 Sat Nov 04, 2006 12:22 AM
vwclass11 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion good bus CV boots available? 1 madman74 1213 Re: good bus CV boots ...
 Sat Oct 14, 2006 02:31 AM
bajasam96 View latest post
