Visitors: 304
Total: 304
64: Pictures
65: Pictures
66: Pictures
68: Pictures
88: My Account
89: My Account
91: My Account
92: My Account
114: My Account
115: My Account
116: My Account
117: My Account
124: My Account
126: My Account
141: Home
158: Baja Forums
162: Baja Forums
164: Baja Forums
166: Baja Forums
170: My Account
171: My Account
172: Baja Forums
173: Baja Forums
176: Baja Forums
180: Baja Forums
187: Baja Forums
188: Baja Forums
189: Baja Forums
190: AMAZON.com
197: AMAZON.com
198: AMAZON.com
200: Baja Forums
202: Home
203: My Account
204: My Account
205: My Account
206: Baja Forums
207: My Account
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
212: AMAZON.com
213: Baja Forums
214: Baja Forums
218: Pictures
219: Pictures
220: Baja Forums
221: Pictures
222: Pictures
223: Baja Forums
225: AMAZON.com
226: Baja Forums
227: AMAZON.com
229: AMAZON.com
230: AMAZON.com
231: Baja Forums
232: AMAZON.com
233: Baja Forums
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: Baja Forums
240: AMAZON.com
241: Baja Forums
242: AMAZON.com
243: AMAZON.com
244: Baja Forums
245: Baja Forums
246: AMAZON.com
247: AMAZON.com
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: AMAZON.com
254: AMAZON.com
255: AMAZON.com
256: My Account
257: Baja Forums
258: AMAZON.com
259: Baja Forums
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: Baja Forums
265: Baja Forums
266: Baja Forums
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: Baja Forums
271: Baja Forums
272: AMAZON.com
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: AMAZON.com
277: AMAZON.com
278: Baja Forums
279: Baja Forums
280: Pictures
281: Baja Forums
282: Pictures
283: Baja Forums
284: Baja Forums
285: AMAZON.com
286: AMAZON.com
287: My Account
288: AMAZON.com
289: Baja Forums
290: Baja Forums
291: AMAZON.com
292: AMAZON.com
293: My Account
294: AMAZON.com
295: AMAZON.com
296: AMAZON.com
297: AMAZON.com
298: AMAZON.com
299: AMAZON.com
300: My Account
301: My Account
302: My Account
303: AMAZON.com
304: AMAZON.com
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- My baja project
My baja project
1 2 3 4
big0067
big0067
Post Post subject: My baja project
Posted: Thu Jul 30, 2009 02:10 AM
I just started my 1970 baja project i just wanted to thank everyone on this site for the great info ive owed a lot of vw.But this is my first total from start to finsh project that ive tryed.But I ordered a bugeye baja kit,header,3in body lift,spritbars,bumpers,from chircos which was some more great info that i found out from this site.Heres my starting pictures ill sent more of my progress.but to everyone here on this site thaxs.
Big0067
p.s i hope thats the rite pictur im new at computer stuff Confused
Post Post subject: Re: My baja project
Posted: Thu Jul 30, 2009 06:34 PM
I can't seen to open up the link.
big0067
big0067
Posted: Fri Jul 31, 2009 03:22 AM
[img]C:\Documents and Settings\Joe\My Documents\My Pictures\img.gif[/img]Ithink i figured it out my 1970 stock beetle.Before the cutting begins
Posted: Fri Jul 31, 2009 04:14 AM
Your getting closer but when I click on it it still does nothing.
Posted: Fri Jul 31, 2009 06:38 AM
You need to use a host site like photobucket.com
big0067
big0067
Posted: Sat Aug 01, 2009 01:41 AM
[img]http://http://[/img]ok let see if that works before pictures
big0067
big0067
Posted: Sat Aug 01, 2009 01:54 AM
Posted: Sat Aug 01, 2009 02:02 AM
I use Photobucket at www.photobucket.com
The first step is uploading your picture, if you have more then one then click on the "add more images"
Find where the picture is in your computer, I have a folder in the computer set aside for just pictures to upload. Click on that add more if needed.
Once you have the picture uploaded got to the picture you want left click on the [img] which will highlight it, right click on the highlighted line and select copy.
Then left click onto your AZbaja where you want it and hit control v. Put an empty line between multiple photos.
Posted: Sat Aug 01, 2009 02:28 AM
Welcome! And the link still does not work. Try photobucket or flickr and copy/paste the link from there.
What part of West-by-God are you from? I'm about an hour from Charlestown, but in Northern Va.
big0067
big0067
Posted: Sat Aug 01, 2009 03:23 AM
hope i have better luck with my baja project than i do try to post pictures
big0067
big0067
Posted: Sun Aug 02, 2009 08:22 PM
ok im rebuiling my motor in my bug i need a new motor to go with the bus trans axe i just got ok im going just put 88mm piston and jugs and a bigger cam to my stock 1600 can a run a turbo with that or do i have to do something specail to run a turbo
siacs
siacs
Posted: Sun Aug 02, 2009 09:43 PM
You can but I would look at some posts from perrib and others I am sure they will chime in
Posted: Sun Aug 02, 2009 09:55 PM
There is a lot to do to build a turbo engine and have it last.
One of the cheapest, simplest to build, good running, longest lasting engines is a 74 mm stroke x90.5 bore which yields 1904 cc. If you don't want to bore the case a 82x85.5 makes a 1883. but you will need to clearance the case or have it done. Combined with a W 100 cam and a single two barrel 40 mm Weber and you have plenty of power for off roading and an engine that should last 60-100k. DPR machine.com can set you up with the crank and rods.
Have you visted Photobucket.com yet. An account there should fix your photo posting trouble.
Posted: Mon Aug 03, 2009 12:42 AM
you need to link to a .jpg for a picture to show up. like this
wideopenmotorsports.us...es/326.jpg
You been linking to a page like this.
wideopenmotorsports.us...s/326.html
see the html at the end. it needs to be a .jpg or some sort of picture type file.
how to get it right click your mouse over the picture. Click properties at the bottom of the bar. It ill bring up the true URL address of the picture.
big0067
big0067
Posted: Wed Aug 05, 2009 03:58 PM
s584.photobucket.com/a...ure023.jpg ok heres my pictures finally thats Perrib well i got all kind of parts from Chirco net pictures it will look a hole lot differt Very Happy
1 2 3 4
5 Admin_AzBaja 6772 Baja Bugs on Wiki need...
1568 mufasavnvmc 998681 Re: what did you do to...
285 MusicManiac 241188 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 9 FREE VW BAJA'S
1199 Dalton 338258 My 69 project
