Latest: bawward
Overall: 3614
Visitors: 116
Total: 116
08: Event Calendar
12: Event Calendar
38: Event Calendar
47: Event Calendar
50: Event Calendar
55: Event Calendar
89: Home
90: Event Calendar
104: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- car will start sometimes but not always
Post Post subject: car will start sometimes but not always
Posted: Wed Jul 22, 2009 08:14 PM
ok i have another problem with my car again, it will start then i will go somewhere then get back in it and nothing not a drizzle of power to the motor. this will happen every so often. then i will have to get someone to help me bump start it so i can get home.
anyone know what this could be from
Posted: Wed Jul 22, 2009 09:14 PM
Note even a click? Battery and cables good? Grounds? If those are good, bring a test light with you and next time it does it, check and see where you lose power at.
Posted: Wed Jul 22, 2009 10:38 PM
yeah all my connections are good and what not.
i have no idea what the hell is wrong with it im dumb founded
Staff Officers
Posted: Thu Jul 23, 2009 12:44 AM
did you install a relay from your key to the starter?
cyberjaw4
cyberjaw4
Posted: Thu Jul 23, 2009 02:18 AM
mine was doing the samething check battery connections then check the wires where they plug into or bolt onto your alt or gen witch ever one you have mine was the wire that gets bolted onto my alt was loose tighten and havent had a glitch sence
Post Post subject: Re: car will start sometimes but not always
Posted: Thu Jul 23, 2009 02:45 AM
You have a voltage drop or an intermittant open.
NavyMike
NavyMike
Posted: Thu Jul 23, 2009 07:25 AM
my bug has push button ignition but it wont turn over. the head lights and the radio work but the accesorry switch and push button start wont turn the engine over...could it be a bad wire or a bad fuse??
Posted: Thu Jul 23, 2009 03:30 PM
The starter circuit is not usually fused. You have a voltage drop and/or an open circuit or the starter is dirty/defective. Start by cleaning all the connections in the starter circuit. With the transaxle in neutral can you apply 12 volts to the starter solenoid to activate the starter. Often times old VWs wiring has been repaired with to small of wire. Often times I would run two 10 guage wires front to back to make a new starter wiring circuit. While not in the original VW circuit , use a fuse link at the battery in case of a short.
Posted: Thu Jul 23, 2009 09:11 PM
thanks guys im going to try some of that stuff
NavyMike
NavyMike
Posted: Fri Jul 24, 2009 07:23 AM
so a bad wire to my starter could shut off the car as im driving because that also happened. doin about 40 miles per hour and then it just shut off.
Posted: Fri Jul 24, 2009 08:18 AM
No the only time the starter is being used is with the key in the start position.
NavyMike
NavyMike
Posted: Fri Jul 24, 2009 09:04 AM
yea so it must be a wire from my ignition because the light sayin its on wont light up and i dont get a turn over when i hit the switch
Posted: Fri Jul 24, 2009 02:09 PM
There is a really big item that has been overlooked here, IF you have the stock trans mounts or the neoprene mounts you MUST HAVE a ground strap from the trans to the chassis. If you have the steel solid mount kit its not necessary but still a good idea. Remember some solid mount kits have a rubber insulator, these require a ground strap too.
Posted: Fri Jul 24, 2009 04:04 PM
It would be more of a be a problem in the ignition/starter switch circuit. The starter could be bad but it would not cause the dummy lights not to turn on.
Posted: Fri Jul 24, 2009 08:22 PM
i had a bit of corrosion on the positive battery cable and i cleaned that up real good and now it seems to have cured the cancer that old betty had.
i will see if she acts up again.
No new posts VW Volkswagen & Baja Bug General Discussion quick help/won't start 5 Pointvirus 3922 quick help/won't start
 Sun Oct 21, 2012 07:42 AM
Pointvirus View latest post
No new posts VW Volkswagen & Baja Bug General Discussion hard start relay 4 vwboat 2881 hard start relay
 Wed Oct 17, 2012 10:18 PM
No new posts VW Volkswagen & Baja Bug General Discussion Start of a new baja 3 Shorty 3564 Re: Start of a new baj...
 Mon Jul 18, 2011 04:14 PM
23 tdubs-83 15040 Re: Ideas to Start a B...
 Fri Dec 17, 2010 07:23 PM
DeathBug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Baja wont start 5 pschneider 2561 Baja wont start
 Fri Nov 05, 2010 10:16 PM
pschneider View latest post
