Visitors: 263
Total: 263
08: Event Calendar
19: Home
39: Home
53: Pictures
60: Event Calendar
65: Event Calendar
67: Event Calendar
68: Event Calendar
71: Event Calendar
72: Event Calendar
80: Event Calendar
87: Event Calendar
90: Event Calendar
94: Event Calendar
96: Event Calendar
101: Event Calendar
102: Event Calendar
106: Event Calendar
120: Event Calendar
121: Event Calendar
122: Event Calendar
123: Event Calendar
124: Event Calendar
125: Event Calendar
126: Event Calendar
127: Event Calendar
130: Event Calendar
131: Event Calendar
132: Event Calendar
134: Event Calendar
135: Event Calendar
136: Event Calendar
139: Event Calendar
141: Event Calendar
142: Event Calendar
144: Home
150: Baja Forums
154: Baja Forums
157: Baja Forums
158: Baja Forums
161: Event Calendar
162: Event Calendar
163: Event Calendar
165: Event Calendar
166: Event Calendar
167: Event Calendar
168: Baja Forums
170: Baja Forums
172: Baja Forums
176: Baja Forums
178: Event Calendar
181: Event Calendar
183: Event Calendar
184: Event Calendar
186: Baja Forums
187: Baja Forums
188: Event Calendar
189: Event Calendar
190: Event Calendar
191: Event Calendar
192: Event Calendar
193: Event Calendar
194: Event Calendar
195: Event Calendar
197: AMAZON.com
198: AMAZON.com
200: Baja Forums
202: AMAZON.com
203: Baja Forums
204: AMAZON.com
205: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: Event Calendar
211: Event Calendar
212: AMAZON.com
213: Event Calendar
214: AMAZON.com
215: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: Baja Forums
221: Baja Forums
222: Baja Forums
223: Baja Forums
224: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: Baja Forums
229: Event Calendar
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: Pictures
235: Baja Forums
236: Baja Forums
237: AMAZON.com
238: AMAZON.com
239: Baja Forums
240: Baja Forums
241: Baja Forums
242: AMAZON.com
243: AMAZON.com
244: Event Calendar
245: Event Calendar
246: Event Calendar
247: Event Calendar
248: Event Calendar
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: Baja Forums
253: Baja Forums
254: Baja Forums
255: AMAZON.com
256: Baja Forums
257: Baja Forums
258: Baja Forums
259: Baja Forums
260: AMAZON.com
261: AMAZON.com
262: Baja Forums
263: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Pics of your stereo systems bug owners i need ideas!
bajamtbiker
bajamtbiker
Post Post subject: Pics of your stereo systems bug owners i need ideas!
Posted: Mon Jun 29, 2009 07:34 AM
So I just got a system for my 68 bug, it currently has no radio at all, so i have no clue where to mount my deck 6x9's and 5" speakers as well as my sub box and amp. Are the door pannels capable of taking a little speaker mounted to it? Anywyas pics or ideas would be great, its converted to 12 volt allrady so i dont need to worry about that. Im even thinking I might try and install my system hidden, so no one can see it, if they look at my dash there will just be a hole!
nath_baja44
nath_baja44
Posted: Mon Jun 29, 2009 12:47 PM
good idea! hide the lot. mine got stolen out of my van 2 weeks after i installed it so now its hidden!!! haha now try steal somethin ya cant see!!!!
Posted: Mon Jun 29, 2009 06:29 PM
they tryed to still mine but failed when i walked out side with a shotgun and shot a round into the air. they wont be messing with my car again
Posted: Mon Jun 29, 2009 10:58 PM
hahaha, im sure dan.
The best way for them to not steal it is, simply not to have one.
Why would you not wanna here that beautiful purrr an ACVW puts out?
bajaboi727
bajaboi727
Posted: Tue Jun 30, 2009 08:45 PM
I can make you a custom, back panel that will hold 2 6x9's and a 10 inch sub.. I can build a box around the sub and it's actually hidden fairly well. It will go behind your rear seat and forms to the back of the body right there. I have the panel cut all I would have to do is get some fabric and put it on to match your interior and bam Smile it rests well back there and sounds awesome...
If you have a glove box, mount your deck in there.. I'm outta town until Saturday night. Sunday AM I will get pics and show you what I'm talking about for the back panel.. It's hard to see because the rear window is at a slant so you can't tell there's anything there. you can also fold the seat forward and have storage in there. it's pretty slick. Let me know if your interested... Smile
bajaboi727
bajaboi727
Posted: Tue Jun 30, 2009 08:48 PM
I MAY be able to fit a 12 depending on what size sub you have.
Brettucks
Brettucks
Posted: Fri Jul 03, 2009 04:21 AM
The speakers suck but this is an idea of a build out that doesnt need the door-- careful, it can easily get crowded on the drivers side--
My recomendations (I used to install for a living) is to get a box behind the seat (if you like crisp sounds 10's canbe great, sometimes 8's with the RIGHT APPLICATION can do fine), get the best pieces and go for good clean watts, good amps cost , but not as much as cheap ones in the long run... if ya want a 'booming system' I can help... but you shouldnt need it for a bug (small interior, back glass perfect for directing sound).. A lot of systems I built that were impressive usually followd the folling recipe--
Decent deck-(not that fancy but good signal/noise ratio)
one good set of front seperates ( a mid/tweeter combo with built in crossover)
A quality amp-- sounds basic but a good amp is usually the part skimped on)
a couple clean subs- the wattage handling means nothing in 98% of systems, efficiency is the key..
for more detail email or pm, or post again....
fatalifeaten
fatalifeaten
Posted: Sat Jul 04, 2009 03:40 AM
Here's thr only station I tune to when I'm rolling the bug.
All flat four band, all day.
--Harlan Ellison
Brettucks
Brettucks
Posted: Sat Jul 04, 2009 05:31 PM
heres a cheap idea--
www.chircoestore.com/c...ts_id=2710
No new posts Events and Get Togethers World Wide Hassayampa Pics/Vids 5 wideopenmotorsports 4136 Hassayampa Pics/Vids
 Sun Nov 22, 2015 10:34 PM
No new posts VW Volkswagen & Baja Bug General Discussion Arizona VW owners - I need your help 10 AZstateParksOHV 5871 Arizona VW owners - I ...
 Mon Dec 30, 2013 03:26 AM
MBReel View latest post
No new posts We Will Host Your Club Forum here New VW website for Phoenix area owners 7 biblethumpncop 10171 New VW website for Pho...
 Thu Sep 19, 2013 03:17 PM
No new posts Projects and Builds Pics of my dads build 10 Reggie 6818 Pics of my dads build
 Wed Apr 25, 2012 02:18 AM
Reggie View latest post
No new posts New Members TrailRail2110-My New Obsession**pics**
40 TrailRail2110 27489 Re: TrailRail2110-My N...
 Thu Jun 23, 2011 05:52 PM
TrailRail2110 View latest post
