Visitors: 114
Total: 114
45: My Account
46: Event Calendar
59: My Account
99: Home
109: Event Calendar
114: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- extended axles trailing and swing arms!!! help
nath_baja44
nath_baja44
Post Post subject: extended axles trailing and swing arms!!! help
Posted: Sun Jun 21, 2009 12:40 PM
just wondering if it is possible to extend the existing axles and swing arms in my off road buggy. i was thinking bout it in the car on the way home and if i can get my rear wheels out another 6 inches or so its going to give me at least another 4 inches lift! is this right?
my axles are on a say... 15 degree angle at the moment.
if it is say.... 600mm to the hub from the gearbox, then i roughly have 6inch of height to underside of engine.
if i extend the axles and swing arms to say... 800mm away from the gearbox still on that 15 degree angle then i should , in theory, have an extra couple of inches lift and travel(with new shocks obviously)
just wanna no wat you guys have done and how to get myself some more lift!!!
there are pics of my buggy in projects and builds under NATHS BUGGY!!!!
thanx again
Nath
Post Post subject: Re: extended axles trailing and swing arms!!! help
Posted: Sun Jun 21, 2009 06:19 PM
Go to blindchickenracing.com he has a lot of good ideas on how to use stock VW components to do what you want to attempt.
nath_baja44
nath_baja44
Posted: Mon Jun 22, 2009 08:50 AM
i want plans to build these myself any ideas? im on a budget and pretty handy with a welder and angle grinder!
Posted: Mon Jun 22, 2009 03:09 PM
I can tell you did not visit BCR's web site. It has the most detailed plans you are going to get on what axle to use with what set back and offset.
Arms are simple but time consuming to get them correct. Start with a 1/2" thick steel plate make a jig to hold the arm to the plate and still allow you to locate the bearing housing back and out the desired distance.
nath_baja44
nath_baja44
Posted: Fri Jun 26, 2009 08:31 AM
well i was just wondering if i can get plans not purchase the arms. ive looked all through the web site a bcr. might contact them to get plans. if anyont else has got plans can they let me no. thanx. nath
kyle_pc_75
kyle_pc_75
Posted: Fri Jun 26, 2009 02:39 PM
Keep looking... Wink http://www.blindchickenracing.com/How_to/2x3reararms/2x3arms.htm
That's about as good a how-to as there is. Every setup is a little different, and as it says on the site, "I realize this is a bit vague but if there is a lot of confusion about building a jig then maybe this is not the project for you."
Good luck
Kyle
Posted: Sat Jun 27, 2009 06:35 AM
No one who builds them for a living is going to give you plans. BCR is as close as you get. It is the same way I built a pair of one inch longer ones years ago.
Crash
Crash
Posted: Mon Jun 29, 2009 03:35 AM
Actually I have plans I don't mind sharing to some since most of the time they come back and buy completed arms anyway. It seems a bit counterproductive but it usually works out in the end.
Mark
Mark Johnson
Blind Chicken Racing
nath_baja44
nath_baja44
Posted: Mon Jun 29, 2009 12:33 PM
hey mark that would be awesome! sent you an email the other day but haven't got anything back yet. ya probly busy building ppl trailing arms.! any chance you could email me them. thanx mate.
nath
nath_baja44
nath_baja44
Posted: Thu Jul 02, 2009 09:26 AM
so mark any chance i can get those plans off ya mate.
nath
nath_baja44
nath_baja44
Posted: Sat Jul 11, 2009 04:54 AM
thanx a bunch mark your a champion. ill let ya no how i go!!!
nath
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 3864 Re: Max angle for rear...
 Fri Jan 29, 2016 04:03 AM
Wattsd View latest post
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 4309 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2894 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion swing to irs 1 Luckyvw13 1834 Re: swing to irs
 Wed Apr 27, 2011 03:56 AM
No new posts VW Volkswagen & Baja Bug General Discussion 61 bug swing axle to 67 bus swing axle help 5 pussiwillow 5113 61 bug swing axle to 6...
 Fri Jan 28, 2011 06:39 AM
Gettinsomeair View latest post
