Latest: ddbug11
Overall: 3596
Visitors: 79
Total: 79
01: My Account
03: Event Calendar
20: My Account
21: My Account
26: Event Calendar
48: Home
49: Pictures
51: Event Calendar
52: Event Calendar
60: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- my clutch is whining...
Post Post subject: my clutch is whining...
Posted: Sat Jun 27, 2009 08:29 AM
my clutch whines at a certain point when i push the peddle in. is this all an adjustment issue or is the throw out bearing taking a poop. it only does it at a certain point. i can make it better by adjusting the clutch cable, but i can't get it perfect. it still does it.
Post Post subject: Re: my clutch is whining...
Posted: Sat Jun 27, 2009 06:34 PM
It sounds like the bearing.
Posted: Sat Jun 27, 2009 07:05 PM
i have a throw out bearing at my house that perri didnt use when he did my clutch it is brand new never been used i will sell it to you for like 15
Posted: Sat Jun 27, 2009 07:45 PM
i should have one at the shop but if i don't i'll let you know on that. i'm definitely not going to butcher jones tomorrow though which sucks.
Posted: Sat Jun 27, 2009 09:28 PM
dang dude i really wanted to see you there bro.
you dont think your car we be done by tomorow
catchbats
catchbats
Posted: Sat Jun 27, 2009 10:19 PM
Just ignore it if you got places to be. Fix it when you get back I've had brand new POS Throw out bearings make noise on start up. It usually stops after it's warm.
Posted: Sun Jun 28, 2009 01:51 AM
the bad part about it is its been doing this for a while. it does this and starts again. and since i'd be driving it out to butcher jones i really don't want to be stranded out there.
i'll be working on it tomorrow. i'm still driving it today because i have lots of things to do today.
Colesifer68
Colesifer68
Posted: Sun Jun 28, 2009 02:41 AM
i doubt it will work unless one of you 2 changed stuff around with your clutch. he needs an early style and i think you have a late model
Posted: Sun Jun 28, 2009 05:46 AM
true true
Posted: Sun Jun 28, 2009 09:17 AM
things should work out okay. the stupid thing though hasn't made noise at all since i've been driving it this afternoon. i've driven about 20 miles and it runs perfectly fine. i still need to pull it apart and figure out whats going on though.
Posted: Sun Jun 28, 2009 11:59 PM
I ended up taking the motor out this morning starting at 8. By 10 I had the motor all the way out, throw out bearing off, and headed to my shop in tempe to get a new one. came back, put the new throw out bearing in and lubed everything up real good and put the motor back in. got everything buttoned back up and fired her up at about 1:30. No more whining clutch and everything seems okay
Posted: Mon Jun 29, 2009 04:36 AM
sweet man now you can romp with us next time we go bro
2180 Baja bug with 091 trans.
11 51BUG50 4798 Clutch and pressure pl...
 Fri Mar 10, 2017 08:22 PM
parts
0 bajablastman1214 2440 Clutch
 Sun Aug 16, 2015 05:23 AM
Really bad issues
4 Pointvirus 2670 Clutch Issues
 Mon Dec 03, 2012 07:33 PM
No new posts VW Volkswagen & Baja Bug General Discussion where to find clutch slave install tips/instr.??? 6 bajabuggin 6429 where to find clutch s...
 Sat Sep 11, 2010 02:58 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion clutch ?'s 11 jone$yyy 4889 clutch ?'s
 Thu Apr 22, 2010 06:16 PM
jone$yyy View latest post
