AzBaja Site info
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- The Crazy Ideas thread
Users browsing this topic:
None
Author |
Message |
impulsenine
Post subject: The Crazy Ideas thread
Posted: Sun Sep 24, 2006 08:15 PM
Hello all,
I would like to hear the unusual customization ideas you have for your Bajas. I have a lot of my own, and I'll share when I see some here. Some moderately wild things are already on the forum - using LineX for the floor covering, custom bumpers and the like. But I'd like to hear some of the really mad ideas, even if they're just pipe dreams so far.
Cheers,
Steve
+13
Post subject: Re: The Crazy Ideas thread
Posted: Sun Sep 24, 2006 09:15 PM
All my crazy ideas will remain secret. That way when one of them works right I can make some money on it.
_________________ Current AZBaja"El Presidente"
impulsenine
Posted: Sun Sep 24, 2006 10:25 PM
Well you don't have to say HOW you do it, so much as WHAT you're doing...
Bajanick
Posted: Sun Sep 24, 2006 10:29 PM
Boxing in stock arms without pulling them......... LOL
+13
Posted: Sun Sep 24, 2006 10:50 PM
Putting a link pin front end on a ball joint pan without modifing the pan head!!
The craziest idea of all..... thinking someday my Baja will be done!!!!!
impulsenine
Posted: Sun Sep 24, 2006 11:08 PM
Alright, as a few examples:
- Winch mount on both front and back bumpers, and have the ability to put the winch on either side.
- I'm going to be fabricating a swamp cooler whose air intakes are on the hood, and the fiberglass water reservoirs will be down those holes on either side of the trunk. I'll be putting the air ducts into the heater ducts on the corners of the dash.
- Line-X interior with drains. I'm going to try to have basically no upholstery in my car so that I can use a hose to clean my cars' interior.
- I'll be fabricating cubbies and tie-downs to put all my various tools and spare parts in the trunk.
- This weekend I'm going to paint my exhaust header with anti-rust oven paint (good up to 1200 degrees, as opposed to engine paint which is only good up to 300).
+35
+13
Posted: Sun Sep 24, 2006 11:43 PM
Thanks Daryll  Ive had that Idea rolling around in my head and on a couple pieces of paper for about a year now, I just dont have the tools to fabricate anything right now.  I am really interested in seeing your design.
bajasam96
Posted: Mon Sep 25, 2006 12:31 AM
Mine has a link pin frontend using a ball joint head. I just cut m own tubes, not really that involved of an idea
_________________ We all do what we have to, until we can finally do what we want to.
+13
Posted: Mon Sep 25, 2006 12:42 AM
Got pics???????
KrazyKarl
Posted: Mon Sep 25, 2006 01:24 AM
" I'm going to be fabricating a swamp cooler whose air intakes are on the hood, and the fiberglass water reservoirs will be down those holes on either side of the trunk. I'll be putting the air ducts into the heater ducts on the corners of the dash."
sorry but can you explain this better, im new to bajas and I have no idea what you are talking about, what is a swamp heater?, why do you need air intakes? what are the air ducks into the heater ducts for?
thanks
_________________ "Imagination is more important than knowledge"
bajasam96
Posted: Mon Sep 25, 2006 05:32 AM
I could get ya some pix up later this week if you wanna see
+1
ak_baja
Posted: Tue Sep 26, 2006 02:06 AM
im working on running an external oil cooler in front on the beam with air slots in the nose. Also im putting a sounds system in my car that will blow the pants off all these little ricers running around  . Using the kick panels cut for speakers, speakers in the rear cargo area, amps in the side panels, maybe subs under back seat, also thinking about using fiberglass to mount speakers under the dash, and these for sure but might be replacing the speakers later on www.jcwhitney.com/auto...87/c-10108
Im also thinking of fab'ing mounts for safari doors www.jcwhitney.com/auto...19/c-10108
KrazyKarl
Posted: Tue Sep 26, 2006 05:54 AM
it'd be sweet to cut the back off a baja and make a truck right. Then remove the engin but leve the transaxel inplace for the suspension to work. then add a engin and propeler from a air boat (302 ford or 351 chev V8 etc) the weight of the V8 would be near the center of the car, and mounted to the roll cage. Put on wide tyres on the back and skinier sand rail tyres on the front for good steering. The cool thing would be if you could rig up power steering in the front and also to the rudder on the back so you'd have like "quadra steer". I think this would be sweet in the sand. Easy to roll though I should imagen. I drew up a quick pic on paint but i cant figure out how to put them on to here.
Topics |
Replies |
Author |
Views |
Last Post |
Events and Get Togethers World Wide
Official 2016 Hassaympa PlayDay Thread!
Sat November 5th
Go to page:
1 ... 4, 5, 6 ]
83 |
Dirtjunkie |
20324 |
Official 2016 Hassaymp... Tue Jan 31, 2017 02:25 AM AzBaja  |
2015 Hassayampa Play Day Official Thread
Go to page:
1 ... 3, 4, 5 ]
60 |
wideopenmotorsports |
24243 |
2015 Hassayampa Play D... Tue Nov 10, 2015 12:22 AM Azdrtdog  |
Go to page:
1, 2 ]
16 |
6499 |
2015 Hassayampa Play D... Thu May 14, 2015 03:18 AM Dalton  |
2014 Hassayampa Play Day Official Thread
Go to page:
1 ... 3, 4, 5 ]
74 |
26210 |
2014 Hassayampa Play D... Sun Jan 18, 2015 11:26 AM AzBaja  |
Projects and Builds
Build Thread
Baja Karmann Ghia
Go to page:
1, 2 ]
27 |
dave46 |
14550 |
Build Thread Mon May 07, 2012 09:29 AM AzBaja  |
Picture Box
Great things to Buy
Other Sites
Parts - For your Car
