Latest: jor_dang420
Overall: 3597
Visitors: 78
Total: 78
03: Event Calendar
13: Event Calendar
16: Event Calendar
22: Event Calendar
23: Event Calendar
39: Event Calendar
40: Event Calendar
49: My Account
61: Event Calendar
71: Event Calendar
78: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- IRS jig
IRS jig
rynoH8R
rynoH8R
Post Post subject: IRS jig
Posted: Mon Jun 01, 2009 03:47 PM
How neccesary is a IRS jig for installing pivots on a swing axle pan? If so, does anybody have one in the PHX area to borrow/rent/trade/sell?
Thanks for your help.
GET TO THE CHOPPER!
Post Post subject: Re: IRS jig
Posted: Mon Jun 01, 2009 07:22 PM
I converted mine with out the jig. But I had an irs torsion housing to take measurements off of. If you have that its easy to do, you just have to measure ten times and weld it once. When I did mine I tried to use a jig but it wouldn't clear the body, that was why I went the measuring, grinding, and cutting a bit here and there to get it right
Colesifer68
Colesifer68
Posted: Mon Jun 01, 2009 09:12 PM
i have talked to alot of people about it. seems like a jig really goesnt do much good unless you pull the body. i have herd alot more people are just doing the measuring method as stated above
rynoH8R
rynoH8R
Posted: Sat Jun 13, 2009 06:12 PM
Thanks for the info. I guess I will have to sack up and do it.....Now where's that yard stick?
GET TO THE CHOPPER!
