Visitors: 86
Total: 86
11: Pictures
12: Pictures
21: Pictures
27: Pictures
65: Links
79: Event Calendar
1 2 3 4 5 6 7 8 9
The following users give thanks for this topic Anonymous - Thu Mar 12, 2009 12:54 PM
cwick1989
cwick1989
Post Post subject: Navy nuke building a baja for Play/Race
Posted: Sat May 02, 2009 05:57 PM
Good God man that things awesome!
Colesifer68
Colesifer68
Posted: Sat May 02, 2009 08:03 PM
wow...really?
navynuke
navynuke
Posted: Fri May 15, 2009 02:30 AM
Dragged it home today. I'll get closeups of the shock mounts ect. tomorrow. had to leave for work. Bugzilla does some great work, for a great price.
gonna spend all weekend getting the motor running, anyone have any tuning tips for the Ford 2.3?
Just a few little things, then going camping in snowflake for memorial weekend, as a shakedown run.
navynuke
navynuke
Posted: Sun May 17, 2009 05:41 AM
better pics of mounts
navynuke
navynuke
Posted: Mon May 18, 2009 06:24 AM
It ran tonight, however briefly. I think the tank needs some more gas in it.. wohoo, I'll get her going in the AM.
Colesifer68
Colesifer68
Posted: Mon May 18, 2009 07:14 AM
car looks sick man. bravo
navynuke
navynuke
Posted: Mon May 18, 2009 06:38 PM
well I had it running a bit today. but it won't be ready for the camping trip I'm going on this weekend.
It has an oil leak from the crankshaft seal, and a couple other dribbles elswhere I need to fix.
brake lines arn't tied down yet
needs a longer throttle cable
and so on. thats ok, it ran for a few minutes in the garage, set of the smoke alarm, and was not as loud as I feared. so I feel better now having put some life into the thing.
navynuke
navynuke
Posted: Tue May 19, 2009 12:27 AM
well got some assistance from bugzylla and Sean, but the damage seems to have been done.
the oil leak isn't scary bad anymore, but the rear main seal, and the cam shaft seal are both leaking still, although much more slowly after unhooking my exhaust crankcase pressure system.
so I guess I gotta lift the motor up to pull the oil pan, and the rear main seal.
grrr, maybe I'll cut my cage, and put flanges in so I can unbolt the part from under the engine.
madman74
madman74
Post Post subject: Re: Navy nuke building a baja for Play/Race
Posted: Tue May 19, 2009 05:11 AM
Hey Ken you dont have to drop the pan for the rear seal but you do have to pull the flywheel. Your engine is a 1pc rear main. The cam seal is easy. The ford 2.3 need to have a PCV valve hooked to it. I didnt check yours to see if you still have the correct peices for a PCV system or not. You need to have A PCV hooked to the beather box on the side of the block. And then the valve cover should have a breather tube running to the air cleaner. If not it will be hard to ever get the 2300 to not leak oil.
I would work on the PCV system befor pulling the engine.
Good luck
Shawn
Oops it broke!
navynuke
navynuke
Posted: Tue May 19, 2009 05:42 AM
ok, I have the breather box under the intake, and on the valve cover. but no hookup on the airfilter. it runs to the header now. I'll look into getting an airbox fitting hooked up soon.
to pull the flywheel, am I better off sliding the trans forward? or sliding the motor back?
thanks for the help guys, couldn't do this without you.
66dannyboy
66dannyboy
Posted: Wed May 20, 2009 03:32 AM
I'm told you may have a rim that I;m loooking for.. 15"x8" wide 5 spoked
inside.. I'm told you have only one and I only need one!! Danny
602 363 7842(cel)
navynuke
navynuke
Posted: Wed May 20, 2009 06:36 AM
nope, sold the one good one and one bad one I had to someone. sorry.
navynuke
navynuke
Posted: Thu May 21, 2009 10:27 AM
well this project just took a bit of a slowdown. I got laid off tonight, and will probably be going back to school full time starting in a few weeks.
wohoo, I guess. it is what it is anyway, and fortunately I have the GI bill to help pay for everything.
Posted: Mon May 25, 2009 07:02 AM
sorry about that, I'm still here for the people that do care, I know about a dozen (long term people) or so people that got let go this week. %40 of my are was let go so kno it's just the 3 of us.
navynuke
navynuke
Posted: Tue May 26, 2009 02:06 AM
glad you still have a job. I'll rebound, just gotta work on some self improvement first. and I'm so close, and so little money left to spend on this, I'll get it running this summer I hope, depending on the heat.
1 2 3 4 5 6 7 8 9
5 Admin_AzBaja 7373 Baja Bugs on Wiki need...
1568 mufasavnvmc 1021215 Re: what did you do to...
285 MusicManiac 246572 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 491 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1635 Re: Had to go play in ...
