Visitors: 37
Total: 37
06: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Clutch Cable Tube
Clutch Cable Tube
stockbug
stockbug
Post Post subject: Clutch Cable Tube
Posted: Tue Sep 19, 2006 06:29 PM
The clutch cable tube where the bowden tube mounts is all ragged and sawed through at the end by the cabel. I was going to slip/pound a smaller dia. tube inside the end. Is there a better way to fix this? I don't want to pull the engine and trans if I don't have to.
Steve
Post Post subject: Re: Clutch Cable Tube
Posted: Wed Sep 20, 2006 02:54 AM
11/32 brass tube should slip right in (with a nudge or two). had to do it with my 59 recently. make sure you gat it an inch or more in past the bad spot.
stockbug
stockbug
Posted: Wed Sep 20, 2006 04:51 PM
All finished and working. I welded a larger tube to the 11/32 tube to contain the bodin tube. Installed the new pedals and cabel from Chrico. The clutch works easy and smooth. Shifting is fast - its ...its like a new car!
2180 Baja bug with 091 trans.
11 51BUG50 2474 Clutch and pressure pl...
 Fri Mar 10, 2017 07:22 PM
parts
0 bajablastman1214 1429 Clutch
 Sun Aug 16, 2015 05:23 AM
No new posts Projects and Builds American Motorsports Tube Chassis Baja
Cabriolet,1.75" DOM Tube Chassis, Honda 3.5, Mendeola, Gear1
4 AmericanMotorsports 3682 American Motorsports T...
 Thu Aug 14, 2014 03:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion sticking accelerator cable 11 65bajabug 3821 Re: sticking accelerat...
 Wed Mar 13, 2013 12:29 AM
nshoe18 View latest post
Really bad issues
4 Pointvirus 2114 Clutch Issues
 Mon Dec 03, 2012 06:33 PM
