Members: 1
Visitors: 110
Total: 111
 Members:
01: ghs215 > Baja Forums
31: Links
58: Contact Admin
64: Event Calendar
71: Event Calendar
92: My Account
97: Event Calendar
99: Event Calendar
103: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Mechanical Turning Brake
glenf
glenf
Post Post subject: Mechanical Turning Brake
Posted: Mon Apr 27, 2009 01:41 AM
Years ago (yes I'm an old fart) you could buy two brake handles that would mount on either side of the hand brake, which would, if pushing them individually, operate the parking brake on whichever wheel it was attached. I want one of these for my Baja. Does anyone know where I could find one (new or used) that would work like this? I don't want a $100 hydraulic job!
glenf in PV
Posted: Mon Apr 27, 2009 01:48 AM
i remember somthing like that,,good idea,,i,m interested in,,where this goes,,
Post Post subject: Re: Mechanical Turning Brake
Posted: Mon Jun 01, 2009 02:04 AM
It worked best for light Dune Buggies. Empi may still sell them. The problem that arises is safety. You no longer have a functional emergency brake.
kyle_pc_75
kyle_pc_75
Posted: Mon Jun 01, 2009 02:14 AM
Why not? Have the turning brake handles to the side of the e-brake handle and pull the cable at a point "above" the e-brake handle. Retain the e-brake handle and have a couple tabs on it pull up both turning brake handles simultaneously. You'd have dual functionality, right? I had actually planned on doing this to my new car, please tell me if my thinking is way off...
Kyle
glenf
glenf
Posted: Mon Jun 01, 2009 02:41 AM
Not true with the BugPack model as the individual handles mount above the regular E-brake and just pull each cable individually. Then when you pull the regular E-brake handle, it pulls both of them. I was able to find a used one on Craig's list, but it is not yet installed - too far down on the priority list. All I expect to do with it is to stop a spinning wheel if I get stuck. It should do just fine at that, especially if I lube the hell out of the cables where the go under the E-brake so that they can slide through the E-brake handle. I got my regulator installed this weekend along with my pop-outs (what a pain!), and the rear fg cover, adjusted the brakes and drove around the block! Very Happy
glenf in PV
Posted: Mon Jun 01, 2009 10:35 AM
I have all wheel disc and no e-brake. If you have to stop real fast with no brakes down shift to 2nd or 1st then turn off the key.
Just do not park it on a hill it will compreshion roll some times.
1 LittleBaja 2192 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 2032 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 3025 Re: Brake light switch...
 Sun Nov 17, 2013 07:21 PM
24 vwboat 10636 Re: lifted spindles an...
 Fri Mar 22, 2013 08:58 PM
what are yall's set'ups
7 vindeta 14164 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
