Visitors: 121
Total: 121
55: Event Calendar
80: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Baja tow bar ??
Baja tow bar ??
The following users give thanks for this topic Anonymous - Wed May 06, 2009 08:17 AM
cowboy
cowboy
Post Post subject: Baja tow bar ??
Posted: Fri Apr 10, 2009 05:51 AM
Hi all, been hanging around for awhile, great site, my first post ! I really need some Ideas for a different way to tow my ,new to me, 73 baja, the regular tow bar that I have is a real pain to put on, and it hits my front bumper on the tow bar crossbar,and won't raise all the way. there just has to be a better way. Thinking about getting the two bar bumper, which is wider than the one I now have, and get an adjustable tow bar and tow off the bumper !! What about that ?? any other Ideas would be greatly appreaciated.no trailer,I don't have room for it.Thanks, Cowboy
70bug
70bug
Post Post subject: Re: Baja tow bar ??
Posted: Fri Apr 24, 2009 04:21 PM
you can extend the tow bar by cutting and welding longer tubes in. an adjustable? hmm like anything that can be made longer or shorter its not very strong. and the bumper idea it would work but i like my baja to be secured and a chinese made front bumper is not the best of quality if you know what i mean. i pull my front bumper off to put my tow bar on, just becuase i like it to be secured to the beam. sometimes the extra work is worth it, to make sure your goods are secured. thats my two cents i hope it gives or points you in the right direction. oh and congrats on the bug there a blast.
Colesifer68
Colesifer68
Posted: Fri Apr 24, 2009 04:44 PM
first off let me say welcome. im new to bajas also but you will learn real fast. the guys here are great. as far as your tow bar goes your kinda stuck. you can redo it like the guy above said but if your going to do that i would just make a whole new one with the part that connects to the beam...or lift your bug!!!
cowboy
cowboy
Posted: Fri Apr 24, 2009 04:56 PM
Thanks all for the info !! I guess I will just cut the crossbar off the tow bar, as my front bumper is welded on,so can't remove it. Oh well such is life !! thanks again, Cowboy
kyle_pc_75
kyle_pc_75
Posted: Fri Apr 24, 2009 06:43 PM
I don't think I'd cut off the crossbar. It could really weaken it and might fail when subjected to lateral forces going around corners and whatnot. Maybe you could move the crossbar farther back towards the beam or fab a U-shaped one on that would clear your bumper?
Kyle
cowboy
cowboy
Posted: Sat Apr 25, 2009 03:21 AM
Thanks Kyle, I was worried about that too, so am going to move the bar closer to the hitch,toward the Baja would still hit my bumper, I think, will have to check later !! thanks for the concern ! Cowboy
Posted: Wed Apr 29, 2009 05:43 PM
You need the cross bar or your tow bar will fold when you turn...
Lotrat
Lotrat
Posted: Tue May 05, 2009 04:15 AM
Yippie 1st post...
I've seen a few guys run the super beetle tow bar. Just weld or bolt on the plate....
Posted: Wed May 06, 2009 01:12 AM
Welcome Lotrat!
4 Admin_AzBaja 5571 Baja Bugs on Wiki need...
1568 mufasavnvmc 888588 Re: what did you do to...
285 MusicManiac 215669 Re: Baja sightings
0 Northmountainauto 29 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1076 Baja hiding in Chandle...
