Visitors: 110
Total: 110
74: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- HOLES
HOLES
Post Post subject: HOLES
Posted: Tue Apr 07, 2009 06:23 AM
i was wondering what you guys do with all the holes that acomulate after a while in the pan and what not.
any suggestions
navynuke
navynuke
Posted: Tue Apr 07, 2009 06:53 AM
I taped the bottom of my pan, and put in a thick coat of truck bed liner. otherwise, they are drain holes to help get water out. Smile
Posted: Tue Apr 07, 2009 04:29 PM
Replace the rusted out areas with fresh metal. If they are drilled holes from a previous modification, weld them up.
kyle_pc_75
kyle_pc_75
Posted: Wed Apr 08, 2009 02:20 AM
Me, I'm just buying a second Baja without holes. Very Happy
I'm too lazy to fix the extensive rust in the car I have, and then I won't feel guilty about DD'ing it in the winter.
But yeah, cut out the rust and weld in new patches, panels, whatever. That's the best way to fix them.
Kyle
DutchBug
DutchBug
Posted: Wed Apr 08, 2009 02:36 AM
Panels are sold in different sizes so you don't have to weld in to big pieces.
Posted: Wed Apr 08, 2009 03:38 AM
im thinking about filling the holes with something and hurcilinear the pan basically then doing some carpet work inside of it.
Posted: Wed Apr 08, 2009 06:00 PM
How big are the holes you're referring to, Dan? If they're just bolt/screw holes, then the tape/Herculiner things navynuke mentioned works pretty well, and is simple to do- no welding required. I did a LOT of that to my firwall...
Posted: Wed Apr 08, 2009 11:27 PM
the holes are bolt hole size.
3/4 in size to be exact there are like ten in the back that need filled then just a ton of little ones from random stuff over the years. so basically i need to tape off the bottom then come in with hurcilinear and go over all of it.
kyle_pc_75
kyle_pc_75
Posted: Thu Apr 09, 2009 01:03 AM
Oh yeah, for sure. I personally like to weld up even those small holes, but mostly because it provides welding practice (I NEED IT!). But it's really not necessary as long as you aren't dealing with nasty rusty repairs.
Kyle
navynuke
navynuke
Posted: Thu Apr 09, 2009 03:15 AM
I had a lot of holes like that in my pan. from things bolted down and such. just use good tape under the holes, and tape it and slap on a good coat of paint or 3. I left the tape on mine, eventually it will fall off the bottom.
Posted: Thu Apr 09, 2009 05:53 AM
Oh- I used that aluminum tape. Buy it at Home Depot in the plumbing section where the air conditioning vents and ducting is (yes, that's the plumbing department!).
No new posts VW Volkswagen & Baja Bug General Discussion Seat belt mount holes 6 locutisj 2660 Seat belt mount holes
 Wed Apr 01, 2009 03:18 AM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Question about all those interior holes... 10 mike240 4756 Re: Question about all...
 Sun Nov 30, 2008 09:18 PM
BajaMike65 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Cutting holes for gauges 5 az350x 2840 Re: Cutting holes for ...
 Sat Jan 19, 2008 01:22 AM
VIN70 View latest post
