Visitors: 127
Total: 127
32: Event Calendar
47: Pictures
62: Event Calendar
94: Pictures
95: Event Calendar
112: Event Calendar
126: Pictures
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- 90xj's baja build
90xj's baja build
1 2 3 ... 8 9 10 11
The following users give thanks for this topic Anonymous - Fri Mar 20, 2009 12:17 PM
Grunt-0341
Grunt-0341
Post Post subject: 90xj's baja build
Posted: Sun Mar 15, 2009 09:22 PM
It's looking good. I can't wait to see the finished project.
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
90xjlimited4x4
90xjlimited4x4
Posted: Tue Mar 17, 2009 09:27 PM
well shes all done got the mount for the race radio antenna on the main hoop got all the stretched metal welded on (what a pain) the racks a bit heaver that i thought it was gonna be but hell its holding a tire!
90xjlimited4x4
90xjlimited4x4
Posted: Mon Mar 30, 2009 07:15 AM
burned some midnight oil tonight
Posted: Mon Mar 30, 2009 09:35 PM
Looks good!!
Grunt-0341
Grunt-0341
Posted: Mon Mar 30, 2009 10:29 PM
It's coming along well.
Grunt-0341
81mm Mortar Man
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
90xjlimited4x4
90xjlimited4x4
Posted: Wed Apr 01, 2009 03:02 AM
got one cv axle in and greased the other side's clips must be wrong there different than the privious side and those fit perfect... the trans in in as well as the motor i need to yank the oil pump and get the full flow oil pump (for now) gotta get a oil cooler and plumb the oil lines car needs a shifter and shift linkage needs brake lines and i think ima go hydrolic on the clutch probally do hanging pedals on the clutch and brake (cnc) not to meantion eat belts (thats the short list) but its a roller and getting close
Post Post subject: Re: 90xj's baja build
Posted: Wed Apr 01, 2009 06:07 AM
damn that thing is looking sweeeeeeeet! Laughing
one question though, it is gonna fit out of the garage with the roof rack right?
90xjlimited4x4
90xjlimited4x4
Posted: Wed Apr 01, 2009 08:04 AM
it unbolts..... its about a half inch to tall (the door bows down in the center) i need a roll up the header measures 79 inches the car measuers 74 3/4 the garage door (center support **lowest point**) measures 73 1/2 with a friends help i dont have to un bolt the rack....... the car with the final weight might sit below the door full of gas with both seats and me in it... maybe but i think i need to buy a door...
navynuke
navynuke
Posted: Wed Apr 01, 2009 08:37 AM
or brace it
Posted: Wed Apr 01, 2009 02:44 PM
well as long as it comes out some how. Very Happy
at least you won't have to disassemble the garage around the car.
how many lights are you gonna run on your rack? and how big?
90xjlimited4x4
90xjlimited4x4
Posted: Wed Apr 01, 2009 04:54 PM
The rack was built for four of the kragen 7" hid's. Those aren't very high on my buying list right now but after the cars all set up and driving I will be buying them.
Posted: Wed Apr 01, 2009 05:05 PM
okay cool. I'm gonna start building a rack for my car and i'm trying to figure how big and how many lights i want, etc.
i'm keeping it simple though and just modifying an all metal beetle roof rack.
Posted: Wed Apr 01, 2009 05:08 PM
I notice you're running a Fram PH8A filter. I've got the same full-flow setup on my car, and run the Fram HP1. Seems like someone mentioned pressure issues with smaller filters (like splitting them with a cold engine). Have you heard anything like that?
90xjlimited4x4
90xjlimited4x4
Posted: Thu Apr 02, 2009 03:11 AM
i have heard of people blowing up filters.... never seen it done. but that ph8a is a filter i had already so im going to use that for now. i plan to run a wix racing filter (much much more filtering capability than the fram comparable units)
when you say your running the same full flow system your running a "in & out" pump?
90xjlimited4x4
90xjlimited4x4
Posted: Thu Apr 02, 2009 03:13 AM
that was my original plan but i didnt think it would fit the build of the car or the look the car had.
1 2 3 ... 8 9 10 11
4 Admin_AzBaja 5227 Baja Bugs on Wiki need...
1568 mufasavnvmc 856696 Re: what did you do to...
285 MusicManiac 209595 Re: Baja sightings
Off-road event
1 wideopenmotorsports 390 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
26 1963BAJA 3918 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
