Visitors: 96
Total: 96
28: Event Calendar
96: Event Calendar
1 2 3 4 5 6 7 8 9
The following users give thanks for this topic Anonymous - Thu Mar 12, 2009 12:54 PM
navynuke
navynuke
Post Post subject: Navy nuke building a baja for Play/Race
Posted: Tue Feb 10, 2009 12:56 AM
took most of this weekend off. I cleaned the rust out of the motor, and will clean up the head tomorrow. not sure how much past that I will do.
instead took the girlfriend and the dog up to munds park to play in the snow, and ride around sycamore on the XR600 today. man is it nice to get out and play a bit instead of just working on the project.
snow
XR at sycamore
a bit of water with the rain.
navynuke
navynuke
Posted: Tue Feb 17, 2009 03:54 AM
ok, progress again, finally!!!!!
oil pan, head and intake back on, cleaned up and painted. had to help cook diner or I woulda finished buttoning back up the motor tonight.
worked out most of my brake line issues/acquired or ordered parts to finish up the brakes. painted the nose cone, and played around with a new awesome camera I got. just dosn't do closeups well without buying another lens. had to stand against the wall in the garage to get these shots, and at the end of the driveway for the other
Posted: Tue Feb 17, 2009 04:00 AM
SHES COME ALONG WAY!
navynuke
navynuke
Posted: Thu Feb 26, 2009 04:10 PM
well the brakes have one more hose to hook up, and they are done, the gauges are in, but not wired yet, I'm procrastinating on the dash wiring.
the motor is almost back together
and scored some stuff off craigslist that will be great once I get some coilovers to go with them. or I heard the fox smooth body shocks I've got can be threaded for coilovers??
3x3 arms, with axles, CV's, bus stub axles, and torsion eliminators.
navynuke
navynuke
Posted: Wed Mar 04, 2009 04:14 AM
well was a good couple of days off. got the brakes all done. just need to bleed them. and the wiring harness is done. just need to clean up the behind the dash stuff.
now I just need a starter. but with no support bushing in the front. will an auto stick one work with a 002 trans? or someone mentioned a Porsche one?
Post Post subject: Re: Navy nuke building a baja for Play/Race
Posted: Wed Mar 04, 2009 05:20 AM
As long as it has the 002 bell housing yes the autostick starter will work.
navynuke
navynuke
Posted: Tue Mar 17, 2009 12:20 AM
the wiring harness is much cleaner now. I've started to paint the roll cage in safety orange. although I think I shoulda primed it where the cage was painted blue. its going on very well over the white I sprayed inside though.
and the auto stick starter went on fine. gonna try it as soon as I set the timing, since I'm at TDC on the motor now. anyone know what the static timing should be on an old ford 2.3?
navynuke
navynuke
Posted: Sun Mar 29, 2009 08:08 AM
well due to needing a larger master cyl. and frying my ignition, I did the truck bed liner on the baja today. with some help
navynuke
navynuke
Posted: Sun Mar 29, 2009 09:42 PM
Had a good time at bugfest today. Scored some good deals. New brake/clutch setup, with throttle
and some Gear one disc brakes for the rear.
the only problem is the hubs are for short stubs, and I'm pretty sure I have long stubs. so I think I can shim it out and make it work. either way the price was right on em. they appear to be new just not in the box.
wohhoooooo
navynuke
navynuke
Posted: Tue Mar 31, 2009 01:16 AM
so I am biting the bullet. gonna order some coilovers.
to support all this stuff
so due to this decision, I'm gonna have some parts people as I clean up the parts.
a set of 4 lug rims, might include the tires if someone wants them enough.
26mm 26 9/16ths torsions, stock boxed rear arms, axles and some fox 14 inch 2.0 emulsion shocks. so if you want any of these, let me know, maybe we can work a deal. otherwise I'll be cleaning them up and posting them for sale.
Posted: Tue Mar 31, 2009 05:24 AM
Got any pics of the Fox shocks? I may be interested...
Thanks.
navynuke
navynuke
Posted: Wed Apr 01, 2009 01:48 AM
ok, so I'm getting ready to order some coilovers from F-O-A and is it worth the extra 100 and change to get 2.5s over the 2.0 with remote reservoir?
thanks for the help guys.
Posted: Wed Apr 01, 2009 05:50 PM
On the rear, YES. On the frt, 2.0's are good unless racing.
navynuke
navynuke
Posted: Thu Apr 02, 2009 03:37 AM
mock up with spring plates and what not. gonna work on mocking it up better, make sure I need 14 inch coilovers this week.
90xjlimited4x4
90xjlimited4x4
Posted: Thu Apr 02, 2009 04:42 AM
drool....................... disc brakes and coilovers!
1 2 3 4 5 6 7 8 9
5 Admin_AzBaja 6809 Baja Bugs on Wiki need...
1568 mufasavnvmc 1000159 Re: what did you do to...
285 MusicManiac 241577 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 34 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1303 Re: Had to go play in ...
