Visitors: 118
Total: 118
18: Event Calendar
41: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- AzBaja
The following users give thanks for this topic Anonymous - Thu Mar 19, 2009 01:51 PM
Post Post subject: AzBaja
Posted: Mon Nov 10, 2008 11:14 AM
Well it's time...I have been driving my Baja for over 14+ years now and it's time for some work... Shocked
1. Fix the electrics, Loose wires, Bad conectors, Lights that work some time etc. etc. etc.
2. Fix ignition New Dizzy (Buy from BugZyla) and MSD 6A etc. (Starting Problem)
3. Replace brake pads.
4. Aluminum Radiator with shrouds.
5. Replace missing Body bolts and screws.
6. Have Custom Coil Holder made/welded up. (BugZyla Welding)
7. Have Passenger O's hit bar redone. (BugZyla Welding)
8. Clutch and pressure plate and throw out bearing.
9. Weld in new brackets for steering stabilizer. (BugZyla Welding)
10. Fix/New Alt. braket
11. Battery Hold Down
12. 930 CV's and Half Shafts (BugZyla) need to check frame horns.
13. New coat of Green and Blue Paint with Clear coat (bajawarrior)
14. Cup Holder
15. Fix Driver review mirrors
16. New Hood
Not all in order and not all will be done, but some have to be done. I will add things as I work down the list.
Post Post subject: Re: AzBaja
Posted: Mon Nov 10, 2008 04:16 PM
I can get you a deal on the radiator too. Cool
Posted: Fri Mar 13, 2009 06:03 PM
Repalced front brke pads, fixed bad/leaking disc brake calipur. Need to bleed braks better.
New starter is in.
14. Cup Holder
16. New Hood
Colesifer68
Colesifer68
Posted: Sat Mar 14, 2009 04:52 AM
number 14...i was just saying how i need a place for my beer. good call
going to be doing alot of the same things to my baja so it will be nice to see how it goes for you.
Posted: Thu Mar 19, 2009 12:16 AM
The Staff Officers at AzBaja.com do not condone the use of alcoholic beverages while operating a motor vehicle. however; if said vehicle is used solely as one rockin cup holder then have a blast! Laughing Laughing Laughing
Posted: Fri Mar 20, 2009 04:47 AM
i said the same thing when i bought my baja.
"dang this thing needs a cup holder."
lol
i just thow it between the seat and the e-brake.
kinda works till you hit a bump and/or a pot hole and then you got a sticky mess on your hands.
Colesifer68
Colesifer68
Posted: Fri Mar 20, 2009 08:26 AM
lmao...perfect
29 AzBaja 28083 Re: "AzBaja Supporting...
 Mon Mar 09, 2009 07:32 PM
cyberjaw4 View latest post
32 AzBaja 30195 Get the www.AzBaja.com...
 Fri Feb 03, 2012 11:36 PM
1966baja View latest post
No new posts Events and Get Togethers World Wide 8th Annual AzBaja Playday 2017
October 6,7,8 2017
19 Dirtjunkie 3551 Re: 8th Annual AzBaja ...
 Tue Oct 10, 2017 06:49 PM
No new posts Events and Get Togethers World Wide AzBaja Playday 2017?
Move Location?
18 Dirtjunkie 3584 AzBaja Playday 2017?
 Fri Sep 29, 2017 10:34 PM
Rigger View latest post
No new posts Events and Get Togethers World Wide 2016 AzBaja.com Hassyampa T-shirt 8 wideopenmotorsports 3569 2016 AzBaja.com Hassya...
 Wed Oct 26, 2016 08:26 PM
