Visitors: 103
Total: 103
13: Event Calendar
17: Pictures
44: Event Calendar
58: Event Calendar
64: Event Calendar
77: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Ditching the Stocker Wheels !
The following users give thanks for this topic Anonymous - Mon Apr 20, 2009 08:38 PM
Post Post subject: Re: Ditching the Stocker Wheels !
Posted: Thu Mar 12, 2009 09:14 PM
DONT wrote:
Don from Chirco's recommended not to get the Douglas wheels for a desert Baja. There are for sand.
I have BTR's for the frt and then everyone ran out of them so I still do not have the rears.
I've got the Douglas' (presumably), with BFG Mud-Terrains, so the tire has that nice lip to protect the bead of the rim from damage. I think that should minimize any problems with bending the wheel(s).
catchbats
catchbats
Post Post subject: Ditching the Stocker Wheels !
Posted: Fri Mar 13, 2009 12:20 AM
Well apparently the wheels they get don't come any other way. Reverse offset is your choice and that's it. It's not like there's a whole lot of choices out there. you either get 3.5" or nothing on a 15x8 wheel. At least thats all I've been able to find.
catchbats
catchbats
Posted: Fri Mar 13, 2009 01:10 AM
Well, I guess running a wheel with a backspace is possible on a wide 5 drum. If it wasn't possible they wouldn't make them. I'd rather have a little back space anyhow because I still have the stock width front end. if I didn't use the BS wheels it would look goofy as hell.
catchbats
catchbats
Posted: Mon Mar 16, 2009 04:56 PM
Is anyone running 15x10's on the rear? I mounted my sandrail wheels on the baja over the weekend and like it! 15x10 with 3.5" BS. 31x10.50's seem to fit good. Just wondering if anyone has had issues running this size of wheel?
Posted: Mon Mar 16, 2009 06:33 PM
It is a good size to run. Changing gear ratios makes it even better. With 31 " tall tires a 1.56 3rd and 1.12 fourth keeps the same engine speed while in 3rd 43 mph @3000 rpm and 4th 60 mph @3000 rpm) Your 1/2 gear mph goes up a couple of mph. If the engine is stock it might feel a little doggy. An Engle 100 or VZ 14 cam cures that.
No new posts VW Volkswagen & Baja Bug General Discussion DEAL ON WHEELS 0 wideopenmotorsports 3197 DEAL ON WHEELS
 Thu Sep 01, 2016 05:16 PM
No new posts VW Volkswagen & Baja Bug General Discussion Wheels and tires. Size is important? 0 andrewbaja 2908 Wheels and tires. Siz...
 Mon Jul 25, 2016 01:44 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion what other wheels fit vw 4 lug 8 bajaben1 7472 Re: what other wheels ...
 Fri Jul 01, 2011 12:15 AM
bajaben1 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Need wheels to fit my baja gear reduction boxes
wheels
6 dustinddm 5260 Re: Need wheels to fit...
 Sat Nov 07, 2009 08:14 AM
dustinddm View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Centerline wheels 5 orbot 6589 Re: Centerline wheels
 Wed Aug 13, 2008 11:41 PM
sandshark View latest post
