Latest: danmcfly
Overall: 3577
Visitors: 121
Total: 121
03: Event Calendar
07: Home
32: Event Calendar
42: Event Calendar
48: Pictures
51: Event Calendar
54: Home
73: Event Calendar
80: Event Calendar
93: My Account
99: Event Calendar
104: Event Calendar
106: Pictures
112: Event Calendar
116: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- love the smell of GAS in the morning...
The following users give thanks for this topic Anonymous - Mon Feb 23, 2009 12:17 AM
Neander
Neander
Post Post subject: love the smell of GAS in the morning...
Posted: Fri Feb 20, 2009 08:27 AM
so ive been having this problem with my baja were when ever i get gas, it REEKS of gas fumes in the cabin of the car.like, if i lite a cigarette in it, car goes boom bad lol. i was thinking that the hard line in the tunnel was leaking somewhere? is there any rubber connections in there that might be leaking? nander out
T_Town_Baja
T_Town_Baja
Post Post subject: Re: love the smell of GAS in the morning...
Posted: Fri Feb 20, 2009 05:41 PM
If its only when you Fill Up with a fresh tank, its most likely the filler tube - assuming you have a 68-up car with a gas door on the pass side.
If the tunnel was leaking, OR even the fitting at the base of the tank, you would have the smell more often than just after fillups.
Blaine
DutchBug
DutchBug
Posted: Fri Feb 20, 2009 07:15 PM
There is an air escape tube (sorry bad English) near the filler tube, that's often the cause of petrol fumes.
If it is gas you smell from the exhaust it is probably a heater hose that is lose.
Often the on that goes from the fanhouse to the exhaust. On the exhaust side. That is close to the end pipe and fumes will be sucked up in the heater system.
Neander
Neander
Posted: Sun Feb 22, 2009 09:50 PM
i took off all of the heater box assembly so thats not the problem. the filler hose and the fitting on the bottom of the tank i just went through so thats not the problem. but it might be that small escape tube thing that dutchbugs talking about. does the gas hard line go from the frame head all the way to the rear fuel line without any other (rubber) connections?
Posted: Tue Feb 24, 2009 12:55 AM
The fuel line in the tunnel is metal from end to end, which does not mean it can't rust and spring a leak. The part about being a full tank points to a tank/sending unit/filler neck issue though.
Neander
Neander
Posted: Wed Feb 25, 2009 06:21 AM
i was driving it just now and felt a slight breeze on my leg, then realizing that air is flowing into the car from the front through the ashtray(which is cracked open) so i think that fumes from the tank vent are coming in from there probably?
DutchBug
DutchBug
Posted: Wed Feb 25, 2009 11:20 AM
Breeze on your leg? Man I get blown away in one of my bugs. Smile
Posted: Wed Feb 25, 2009 06:15 PM
Is the top of the tank dry? If so look at the filler neck/vent tubes.
Neander
Neander
Posted: Thu Feb 26, 2009 07:28 AM
all the tubes look dry, but i kan smell very strong fumes from the vent tube rite next to the filler neck so that could be the culprit.
Posted: Thu Feb 26, 2009 07:46 PM
That is what I would replace then! Cool
No new posts VW Volkswagen & Baja Bug General Discussion love to own a baja bug 3 ironman 2190 love to own a baja bug
 Wed Sep 30, 2015 02:58 AM
No new posts New Members FNG: non-VW owner (but love 'em all the same) 6 DR1665 3945 Re: FNG: non-VW owner ...
 Sun Jun 10, 2012 06:05 PM
No new posts VW Volkswagen & Baja Bug General Discussion I smell gas 12 chickenpants 2819 Re: I smell gas
 Thu Apr 22, 2010 02:31 AM
No new posts VW Volkswagen & Baja Bug General Discussion I love AZ DMV!! (no misprint) 11 Brettucks 6709 I love AZ DMV!! (no mi...
 Sat Feb 06, 2010 11:21 PM
njmedic3306 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Good Morning Zyla 2 bajawarrior 1361 Re: Good Morning Zyla
 Tue May 27, 2008 10:49 AM
