Latest: xbluegto
Overall: 3573
Visitors: 187
Total: 187
18: Event Calendar
37: Event Calendar
53: Event Calendar
54: Event Calendar
63: Home
69: Pictures
71: Event Calendar
133: Event Calendar
141: My Account
150: Baja Forums
157: Baja Forums
172: Event Calendar
181: Baja Forums
182: Baja Forums
184: Baja Forums
187: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- brake pedal is sticking...
Post Post subject: brake pedal is sticking...
Posted: Tue Feb 17, 2009 03:16 AM
when i go to break my pedal gets stuck half way.
and some times to the floor.
so i have sprayed it with wd40 but it only last a little while before im searching for the can and shhhh spraying the crap out of it again.
anyone had this problem.
anyone know how i could fix it.
Posted: Tue Feb 17, 2009 03:54 AM
need help asap
siacs
siacs
Post Post subject: Re: brake pedal is sticking...
Posted: Tue Feb 17, 2009 05:57 AM
Does it get stuck like a mechanical lock? Like someone put a stop pin in it? Mine was doing that except at the top. Pretty scary when coming to a red light and the pedal won't move it turned out to be rear rubber brake hoses
Posted: Tue Feb 17, 2009 06:22 AM
no it just gets locked up half way some times. and some times to the floor. i dont know why.
it did it before but not for this long.
i just use my foot to kick it back.
Posted: Tue Feb 17, 2009 05:05 PM
My advice is not to drive it in the Baja's unsafe condition (to you and the people around you) until the cause ois found and repaired.
The dark side is a lonely place. It is true if your fist stays close nothing can fall out but nothing can go in. What is wrong? I know and many in the forum do but you have some old unresolved issues to atone for. Its time to look into your soul. Coming clean is good for your soul and your stopping abilities. Shocked
Posted: Wed Feb 18, 2009 05:30 AM
i can still drive it but it just gets stuck some times. i think it might be the spring?
i know that i owe you, and i appreciate the help you have gave me. i will pay you back one way or another.
Posted: Wed Feb 18, 2009 07:14 AM
We have it in writing, Young man gets a job and a blonde for a girlfriend can sometimes forget his friends. Get a flashlight and see waht kinmd of junk is aroud the prdal assembly. If the sprink was broken it would not return all the time. I the pedal is actually dropping 1/2 way or all the way to the floor randomly the master cylinder may need replacing. This assumes you have enough brake fluid in the resevoir and the brakes adjusted properly, no worn out backing plates or damaged/ missing hardware.
Posted: Wed Feb 18, 2009 11:38 PM
i think im going to give it a good cleaning spring and under the pedal and what not. and fill the brake fluid all the way up and see what happens. then we will go from there thanks perri
Posted: Fri Feb 20, 2009 07:01 AM
got it fixed finally.
here is the story:
my pedal has been sticking for a week now and what not as previously said so today i got off work at 8 and im like well lets see if i can get my brake fixed today.
anyway i went to the car wash and vacumed the pedal assembly as good as i could with one of those huge vacumes. and nothing still sticks
so im like well im going to go to pep boys on my way home. and i talked to this vw guy about it and he was saying to check it for dirt and rocks. like perri said. and to clean out the break fluid. so i get home tired of dinking with this thing and i get down by the pedal assembly with a big dome light and start screwing around with it. with a screw driver. and cleaning the dirt out and rocks and using some degreaser and what not to get the crap out of there. so im messing around and bang right under the brake pedal there is a valve screw that i broke a while back that i probably threw into the car or something or it fell out of my pocket or something stupid.
anyway it works now and im glad i got it fixed with out to much hassle.
thanks perri and the rest of the guys for the ideas.
thanks again.
1 LittleBaja 1755 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 1676 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 2610 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
24 vwboat 9274 Re: lifted spindles an...
 Fri Mar 22, 2013 08:58 PM
No new posts VW Volkswagen & Baja Bug General Discussion sticking accelerator cable 11 65bajabug 4097 Re: sticking accelerat...
 Wed Mar 13, 2013 12:29 AM
nshoe18 View latest post
