Visitors: 111
Total: 111
86: My Account
98: Home
109: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Engine troubles!!!! help plz!!
Jordynarz
Jordynarz
Post Post subject: Engine troubles!!!! help plz!!
Posted: Sun Sep 10, 2006 04:39 AM
Ok I got my engine running after putting in new plugs. It sounded rough for a little bit, then I shut it off and started it again. And it ran alot better then all of a sudden it died!! and not it won't turn over!! But the thing is that is has oil in it and had no reason to freeze. But I don't know if it froze though. I need help please. Any advice?
ps. The engine was rebuilt a couple of years ago but had never been used. So technically it is a NEW motor!!!
saltyslug
saltyslug
Post Post subject: Re: Engine troubles!!!! help plz!!
Posted: Sun Sep 10, 2006 05:10 AM
if it ran fine then suddenly nuthing you better double check your wires and all your connections. also make sure your batt is up to par. get a $2 test light and it will be your best friend for a vw wiring system. Evil or Very Mad
ps: get a v6 (you barely notice when a plug wire has came off)
Posted: Sun Sep 10, 2006 06:36 AM
if you can turn it over by hand it is not froze.
check your ignition parts, points etc.
Jordynarz
Jordynarz
Posted: Sun Sep 10, 2006 07:57 AM
When I turn the ignition the engine doesn't turn but it turns when I put it in 3rd and push on it. I have a new starter in it. I'll see more about it tomorrow.
Posted: Sun Sep 10, 2006 09:19 AM
Sounds like battery, starter and/or connection. Did you try jumping it?
Posted: Sun Sep 10, 2006 10:06 AM
how bout the starter bushing or any loose wires....
saltyslug
saltyslug
Posted: Sun Sep 10, 2006 07:00 PM
new starter?? maybe the connector fell off, it happens alot. it sounds like you need to buy a BFH if you don't already have one!!!! I hate to threaten my baja but sometimes it just need a little push.........ya know what I mean????
Posted: Sun Sep 10, 2006 07:23 PM
Ya, like my kids! BFH works great! Laughing
Jordynarz
Jordynarz
Posted: Sun Sep 10, 2006 08:32 PM
It does not turnover . But it makes no sense that it froze. Because it had oil.
Posted: Sun Sep 10, 2006 09:58 PM
I'm confused, does it turn over my hand? Car in neutral, big wrench on pulley bolt.
Jordynarz
Jordynarz
Posted: Sun Sep 10, 2006 11:05 PM
No it does not turn by hand I've tried the big wrench and it won't turn. So I don't know why it froze because it had oil.
Posted: Sun Sep 10, 2006 11:36 PM
thats in neutral and your turning clockwise, correct?
wrench on crang pulley bolt. turn to the right (passenger side). trans in neutral first.
Posted: Mon Sep 11, 2006 12:28 AM
We had the same thing happen a few years back. You say it was rebuilt but never used? When it happened to us no one had cleaned out the oil galleys of the crank, so as soon as the oil pressure came up it pushed all the metal shavings into the bearings and froze the engine in under 2 min.
Posted: Mon Sep 11, 2006 01:21 AM
Did you try to turn it both ways? If it will turn one way and not the other, it maybe something wedged between the piston and the head.
Jordynarz
Jordynarz
Posted: Mon Sep 11, 2006 03:01 AM
Yes it doesn't move at all!!
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 1132 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 1854 Re: Engine Work
 Mon Jan 08, 2018 12:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 2261 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 2333 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 4800 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
