Visitors: 156
Total: 156
18: Pictures
24: Event Calendar
48: Event Calendar
62: Event Calendar
71: Event Calendar
76: Event Calendar
81: Event Calendar
118: Garage
150: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- ford 2.3 and 3x3's?
ford 2.3 and 3x3's?
nube_w_1970baja
nube_w_1970baja
Post Post subject: ford 2.3 and 3x3's?
Posted: Sun Feb 08, 2009 06:16 AM
still seriously considering doing the 2.3 and 091 set-up for my bug, just wondering how neccesary going all the way to 3x3's are? i know 3x3's look cool with their stance and long travel shocks mounting to the cage, but....
can 2x2's (for the same price of 3x3's) properly support the weight of the 2.3ford motor, while still providing the correct dispersion of weight using the factory upper shock mounts?
i'm thinking it might be easier/cheaper to go to the factory upper shock mounts rather than getting the "long travel" shocks to mount to the roll cage. also, the 2x2's use stock length bus CV's, rather than the pricey 930's...
Posted: Sun Feb 08, 2009 06:59 AM
You use the 3x3 arms to get more travel and better angles for your CV's Shorter arms will hold up just fine, you will need a 27mm-28mm rear torshion bars. I run 29mm bars with my 3x3 arms.
navynuke
navynuke
Posted: Sun Feb 08, 2009 03:14 PM
I have standard arms with my 2.3. they are boxed, but thats it.
and an extra motor now if your interested, let me know.
Posted: Mon Feb 09, 2009 10:45 PM
I don't know how much travel you can get with shocks mounted on the top of the arm and using the OEM upper mounts.
No new posts VW Volkswagen & Baja Bug General Discussion *** STOLEN White 2004 Ford F250 Truck ***
*** Stolen White 2004 Ford F250 Truck ***
7 Conundrum 3130 *** STOLEN White 2004 ...
 Sat Dec 19, 2015 07:36 PM
No new posts VW Volkswagen & Baja Bug General Discussion Ford EFI 2.5 in baja 3 VWracin2win 1825 Ford EFI 2.5 in baja
 Sun Jan 18, 2015 10:21 AM
No new posts VW Volkswagen & Baja Bug General Discussion king pin spindles and ford tie rod ends ? 10 DRUMMOND 4708 Re: king pin spindles ...
 Sat Feb 02, 2008 04:37 PM
No new posts VW Volkswagen & Baja Bug General Discussion for sale 1978 ford 1/2 ton p.u 900.00 0 bajawarrior 1160 for sale 1978 ford 1/2...
 Wed Dec 12, 2007 08:48 PM
bajawarrior View latest post
No new posts VW Volkswagen & Baja Bug General Discussion '39 Ford Tail lights 2 Preston 1361 Re: '39 Ford Tail ligh...
 Thu Nov 29, 2007 03:03 PM
Preston View latest post
