Latest: danmcfly
Overall: 3577
Visitors: 154
Total: 154
09: My Account
15: My Account
52: Home
53: Event Calendar
67: My Account
71: Event Calendar
81: Event Calendar
98: Event Calendar
103: Event Calendar
106: Event Calendar
139: My Account
146: Event Calendar
1 2 3 4 5 6 7 8 9
The following users give thanks for this topic Anonymous - Thu Mar 12, 2009 12:54 PM
Post Post subject: Re: Navy nuke building a baja for Play/Race
Posted: Tue Jan 27, 2009 07:25 AM
I happen to know of another,that is that clean!! Wink look,n good,,looks like you and i are work,n on the same thing!
navynuke
navynuke
Post Post subject: Navy nuke building a baja for Play/Race
Posted: Tue Jan 27, 2009 08:37 AM
only clean because I've never had it running. won't stay that way I'm sure.
Posted: Wed Jan 28, 2009 04:06 AM
Laughing After seeing your metal door panels and your speakers, I keep thinking the same thing- you're gonna need a bigger set of speakers!
(I've got a metal interior like that, and it'd take a LOUD stereo to be heard over all the racket inside the car!)
Shocked
navynuke
navynuke
Posted: Wed Jan 28, 2009 06:35 AM
we will see. the speakers in the box were 15 bucks. its a place to start. and may make changes as needed
navynuke
navynuke
Posted: Thu Jan 29, 2009 12:20 AM
awwww bugger, filled the coolant system last week, and the level dropped a fair amount. thats odd, no signs of water on the outside dripping anywhere, so pulled the oil drain bolt, and got this
anyone familiar with these engines know if its more likely a head gasket, or cracked head or block, or something else?????
also fighting a messed up brake system. any tips on bending the hard lines to get them into place?
Posted: Thu Jan 29, 2009 10:54 PM
Unfortunately will have to pull the head to inspect.
Do you have a tubing bender? If not Daryll can fix you up.
acousticrawk
acousticrawk
Posted: Thu Jan 29, 2009 11:36 PM
suck a duck. not much worse than finding the milk shake, cause then you know you in for some work. i guess thats what nice about air colled engines... no chance of coolant getting in your oil and eating you bearings... maybe a rebuild is in order since youll be there? very interested to know what you do. goodluck, and looks like it will be a pretty sick little whip when your done.
Bring'n West Coast Baja Bug Madness to the Easy East Coast!
navynuke
navynuke
Posted: Thu Jan 29, 2009 11:42 PM
well found another motor on craigslist for 200, just gonna swap that in, and then look into this to see what it will take. anyone interested in an adapater for a ford 2.3 to a VW? the guy has one.
Ken
acousticrawk
acousticrawk
Posted: Thu Jan 29, 2009 11:44 PM
yeah! i would be! PM me!!
navynuke
navynuke
Posted: Fri Jan 30, 2009 01:02 AM
pulled the header and valve cover today, signs of milkshake and rust on the valve train, and the cam is toast.
look for yourselves.
Posted: Fri Jan 30, 2009 02:35 AM
2.3 Fords are notorious for cracking beween the intake and exhaust seats. Thats what I would look at first.
acousticrawk
acousticrawk
Posted: Fri Jan 30, 2009 02:23 PM
i have a question for you... how common is it that the 2.3 will blow a HG or something "screaming" (<haha, i knwo right?) across the desert? how reliable is it?
Posted: Fri Jan 30, 2009 10:22 PM
They can be very reliable stock and be built up to crazy power. Talk to Madman74 aka Shawn, he is a 2.3 guru.
acousticrawk
acousticrawk
Posted: Fri Jan 30, 2009 10:35 PM
right on, thanks!
navynuke
navynuke
Posted: Sat Jan 31, 2009 02:52 AM
well I bought a new motor today, and its not a 2.3......
its the older german 2.0 from a 72 pinto.
header looks like it will swap, blocks look the same as far as bolting up, taking a 160 dollar gamble that I can make this work, or frankenstein them together.
but I'm open to any advice ect.
the older one has a smaller 2 barrel carb, not sure if the motorcraft intake setup is worth swapping, or what.
thats the new motor. gonna be putting it on the stand and cleaning it up some tomorrow before the bugfest.
see you guys tomorrow
1 2 3 4 5 6 7 8 9
4 Admin_AzBaja 6062 Baja Bugs on Wiki need...
1568 mufasavnvmc 941701 Re: what did you do to...
285 MusicManiac 226966 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 284 Re: Had to go play in ...
No new posts Events and Get Togethers World Wide 2018 AZBaja 9th Annual Play Day, Date.... 0 Dirtjunkie 488 2018 AZBaja 9th Annual...
 Wed May 23, 2018 03:59 PM
