Latest: George
Overall: 3576
Visitors: 102
Total: 102
29: Event Calendar
32: Event Calendar
44: Contact Admin
55: Event Calendar
61: Event Calendar
89: Event Calendar
91: Event Calendar
1 2 3 4 5 6 7 8 9
The following users give thanks for this topic Anonymous - Thu Mar 12, 2009 12:54 PM
navynuke
navynuke
Post Post subject: Navy nuke building a baja for Play/Race
Posted: Sun Jan 18, 2009 06:32 AM
hadn't really planned out the front end. its a widened beam with towers now, but hadn't really decided on much else. won't be able to afford to do much to the front for a while. thanks for the tip though
nube_w_1970baja
nube_w_1970baja
Posted: Tue Jan 20, 2009 02:58 AM
from the first few pics, it looks like your motor isn't held up by anything but the trans. is it?
also, does anyone know how the ride is without having 3x3's or bigger trailing arms?
i've found a running motor, an adaptor plate and have the money, what else is neccesary or what have you done to make things work?
navynuke
navynuke
Posted: Tue Jan 20, 2009 05:32 AM
the motor has solid mounts to the rear bumper cage work. its very solid.
if you want to come look at it, feel free I'm off work tuesday so anytime is good. Mine doesn't even have the factory horns for the trans anymore. still running stock trailing arms, not sure how it will drive, as I havn't had it running since I got it. although it is getting closer every day.
got almost all the wires run today, dash stuff is only partway hooked up, but waiting on a few things for that.
then I need to finish putting together the passenger side CV, bleed the brakes/clutch, and fire it up. see if the carb needs a rebuild or not.
Ken
Post Post subject: Re: Navy nuke building a baja for Play/Race
Posted: Tue Jan 20, 2009 07:10 AM
The added weight on your torsion bars is going to be the biggest issue. You may run into bending issues with stock (unboxed) rear trailing arms too if you beat on it too much. Beefier torsion bars are definitely going to be needed due to the added engine weight.
navynuke
navynuke
Posted: Tue Jan 20, 2009 05:31 PM
engine mount to cage
and trans mount, with boxed trailing arms.
no clue what torsions are in it, planning on 3x3 and coilovers, but gotta get it running first, and keep looking for some used parts.
navynuke
navynuke
Posted: Tue Jan 20, 2009 07:18 PM
ok, need some more advice, I'm getting ready to mount the fuel cell, should the outlet on it be towards the front or the rear? towards the front I'll put in a cutoff valve either way where I can reach it. less fuel line pointed forward, but don't want to have fuel delivery issues.
running an RCI fuel cell setup from summit racing, 16 gallon size.
thanks again for all the help guys.
Ken
Posted: Tue Jan 20, 2009 07:36 PM
Does that engine setup utilize an electric fuel pump, or what? If it's not, the height of your cell relative to engine height may be an issue to consider. Bear in mind I know nothing about 2.3 Fords other than many came from ugly little cars that had a tendency to explode.
As for your torsions- can you see any numbers stamped on the visible end of the torsion? My SAW 28mm bars have "1228" stamped on the ends, which is the model number. Might help...
navynuke
navynuke
Posted: Tue Jan 20, 2009 08:35 PM
I don't see any numbers etched in the torsions? and if I need some what size? almost not worth it if I want to slap 3x3s and coilovers on it.
Yes I have an electric fuel pump under the the fuel cell. going to put the cutoff valve between the tank and the pump.
navynuke
navynuke
Posted: Wed Jan 21, 2009 12:26 AM
update, just talked to prior owner, and the rear torsions were replaced with larger ones, but the guy before him did it. so they arn't stock, but not sure how much bigger they are. gonna get it going and see how the rear end feels.
navynuke
navynuke
Posted: Wed Jan 21, 2009 09:46 AM
ugh after breaking the new windshield tonight trying to put it in, anyone who has done it before want to lend a hand this weekend?
Ken
navynuke
navynuke
Posted: Thu Jan 22, 2009 03:07 AM
ok, need some more advice on brakes. I had one bad wheel cyl. in the rear, and the brake line broke off the hardline.
I have a flair tool, will it work ok, just clean up the end of the tubing, and put a new flair on it? or replace the line?
need at least one new wheel cyl. and brake pads too.
can't wait till I get to the front end of the car and find out whats broken in those brakes.
good news is I found my fuel cell has a level sender in it, so I just need a 0-90 ohm gauge and I'll have a gas gauge. and the wiring harness is half way tucked into conduit and ziptied into place.
navynuke
navynuke
Posted: Mon Jan 26, 2009 07:33 PM
well got the rear brakes mostly done..., having wheel bearing issues now.
I installed the door panels, cut a new dash, cleaned up the wiring harness, put in the fuel cell, and placed speaker box where I think it will go. now i just need some tabs to bolt it to the cage. thinking just clamp type will be fine for the speaker box, anyone have a type they recomend?
and eye candy
aluminum
fuel cell/speakers
wow the wires all bunch up and clean up alright from the nest it looked like yesterday.
Posted: Mon Jan 26, 2009 08:12 PM
Looking Good!
Posted: Tue Jan 27, 2009 06:57 AM
Shocked cleanest baja interior i've ever seen Cool
Posted: Tue Jan 27, 2009 07:04 AM
Preston wrote:
8O cleanest baja interior i've ever seen Cool
what he said...
my car is dirty still and dirt and crap inside.
cleanest i have seen
nice door panels by the way
1 2 3 4 5 6 7 8 9
4 Admin_AzBaja 5911 Baja Bugs on Wiki need...
1568 mufasavnvmc 926572 Re: what did you do to...
285 MusicManiac 223744 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 77 Re: Had to go play in ...
No new posts Events and Get Togethers World Wide 2018 AZBaja 9th Annual Play Day, Date.... 0 Dirtjunkie 329 2018 AZBaja 9th Annual...
 Wed May 23, 2018 03:59 PM
