Latest: hulkbaja
Overall: 3594
Visitors: 138
Total: 138
16: Event Calendar
28: Pictures
29: Home
48: Home
51: Event Calendar
62: Event Calendar
85: Event Calendar
95: Event Calendar
97: Pictures
99: Event Calendar
129: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- type 1 to 091 conversion?
nube_w_1970baja
nube_w_1970baja
Post Post subject: type 1 to 091 conversion?
Posted: Tue Jan 20, 2009 05:49 AM
i was wondering what is the difference in size and length of the typr 1 compared to the 091 trans. i'm thinking about doing the Ford 2.3, but not sure if my stock one will handle it long enough till i am able to afford a strnger trans.
i keep seeing 3,5 and 6 rib transmissions on craigslist for about $450 bucks. are these pretty well roasted or still ok to use?
or would it be better to just go to Don's Bus boxes and get a rebuilt 6-rib for $1100-core...?
Posted: Tue Jan 20, 2009 11:14 PM
The stuff on craigslist is always an unknown. Rebuilt will give you peace of mind, for not much more money.
Posted: Tue Jan 20, 2009 11:26 PM
I don't know your present/future HP numbers, but if you plan on beefing up that motor to upwards of 175HP or so, a stock (albeit freshly rebuilt) box probably isn't going to be the long-term solution you're hoping for. Super-diff, altered gear ratios, etc. are likely going to be needed, and that translates to- you guessed it- $$$$$$!!
I think Don's has a modded, fresh 091 on CL right now with NO CORE for $1,500. Might be an 002 though- I forget...
nube_w_1970baja
nube_w_1970baja
Posted: Thu Jan 22, 2009 04:51 PM
after reading some of what Scott/baja warrior has done with his set up, i'ld like to have something similar. i'ld like it to be my daily driver, but also to be very dependable, on and off road.
my transmission is my weakest link after replacing the motor. as for power, enough to get going in traffic, stay at 65 comfortably and not be scared of going off road, possibly breaking something that's going to cost 400$ + to replace...
dependability is the main focus.
if i have to wait to get this done right, i'll wait.
but decent power 80+ HP and no worries about something breaking is what i want.
Post Post subject: Re: type 1 to 091 conversion?
Posted: Fri Jan 23, 2009 03:28 AM
The 091 6 rib is about 2 inches wider 1 inch each side then the T-1, pretty sure it also sits more to the left (I believe). Length wise, I think about the same..
Here is a 3 rib 002 and 6 rib 091, I should of put the T-1 in the pic but was just changing over when I took this one.
Posted: Fri Jan 23, 2009 04:55 AM
if you drive the freeway in the baja alot, you might what to change out four gear or run a tall tire like a 33". i had 31" on my rail with a 22r and it would rev like the dickens in four... it was a 002
No new posts VW Volkswagen & Baja Bug General Discussion Type 1 V.I.N. Numbers.
17 BugZyla.com 15782 Type 1 V.I.N. Numbers.
 Mon May 07, 2012 08:55 PM
ChinookFE View latest post
No new posts Projects and Builds my 74 Ghia conversion 3 _-Mad-Max-_ 3104 my 74 Ghia conversion
 Sat Jul 20, 2013 12:08 AM
_-Mad-Max-_ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Link Pin Conversion 8 Bryman042 6751 Re: Link Pin Conversio...
 Thu Jun 23, 2011 12:41 AM
Bryman042 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Mazda 13b Turbo Conversion 2 logan44 3599 Mazda 13b Turbo Conver...
 Tue Jun 21, 2011 09:00 PM
HuggingxCorners View latest post
No new posts VW Volkswagen & Baja Bug General Discussion type 3 fi 2 tsutt 1859 Re: type 3 fi
 Fri Jun 17, 2011 02:42 PM
1915cc_Street_Rail View latest post
