Visitors: 90
Total: 90
24: Home
72: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Welder Choice
Welder Choice
JumpinBruceB
JumpinBruceB
Post Post subject: Welder Choice
Posted: Wed Jan 14, 2009 09:42 PM
So I work at lowes and this weekend we are running a big sale and employees will be getting an additional discount (on top of our employee discount) so I would like to take the chance to pick up a welder. But since i know little to nothing about welding I have had to ask a few people at my store and they have suggested one of these two models. Now I do plan on welding in a cage ounce i get the bender (probably at the end of next month) and also some sheet metal here and there. So i guess my question for you guys is will one of these welders do me right or should and just get a little more cash and buy something else? and If this will do the job then which would you recommned? THanks guys and sorry for that being a little wordy.....
first (cheaper)
second
Oh and i DO have a 220 outlet in the garage so that is not a factor
Athlon64
Athlon64
Posted: Thu Jan 15, 2009 12:08 AM
NO NO NO! Go to the welder depot And you can get a better welder for the money, I got the clark 180 220volt and useing 75=25 co2 and argon mix and set the flow meter to 2.5 cfp and with standard 70,000 psi mild .023 wire you will be welding like a pro in no time, if you have a steady hand.
of corse
this welder is a mig and it will do steel alumnuim, stainless, cast iron. .nickle, depending on the wire and gass used. the link to the welder depot and to get good welds you want to use gas
110v store.weldingdepot.com...mage=.html
220v
store.weldingdepot.com...d=HMjjiPbX
Post Post subject: Re: Welder Choice
Posted: Thu Jan 15, 2009 12:09 AM
Go with the 220 you will be glad you did. Also run it with the gas, I use a 75/25 mix of carbon dioxide and argon. The flux core wire makes for some ugly welds, and its more expensive than the standard wire. I get the 10 lb spools from harbor freight, they are only $20 there versus $35 at a welding store.
JumpinBruceB
JumpinBruceB
Posted: Thu Jan 15, 2009 01:12 AM
so zyla are you agreeing that i should go with the 220 from the welder depot?
Posted: Thu Jan 15, 2009 02:23 AM
Miller, Hobart or Lincoln MIG welders are the best choices. They are American made and have a huge parts/service network.
The 130-140 amp 120 volt welders will weld most anything on a rail or Baja. They also do not need a $6/ft wire for an extension cord. My first frame machine was welded with a 125 amp welder and my friend is still using it 25 years later. No welds have broken.
If your welsding 1/4 inch or thicker steel constantly get the 175-300 amp 220 volt welders.
I have the Miller 175 and it has worked perfect for 12 years.
Athlon64
Athlon64
Posted: Thu Jan 15, 2009 12:43 PM
Well Im building a rail and doing alot of welding, up to 1/4" in some areas. The hobarts and lincons are $500+ The clarks are american made and you can get tipps and parts at your local sears store. Or northen tool. But if your just doing little stuff and not alot of it then the 110v will probley be ok.
Posted: Thu Jan 15, 2009 05:00 PM
The Clarke is an entry level welder assembled in the USA with most of the parts sourced from Itay. The drive motor is problematic and the mig guns cables are short. It is way above HF in quailty but short of the big three. My 125 amp ALL Star body shop mig was made in the USA from Italian parts and USA parts. It had stich weld features spot weld shrinking features. In 1982 it was $1100. Only a couple hundred less than a USA made one but the Matco Tool Man would finance it for $100 month no interest. I used it all the time and worked fine until 1996. Then as usual for asemblers the company had long stopped assembing them and stocking parts for them.
For just working on VWs or rails the Miller 140 would be my first choice. There might be a couple of places that require V'ing and two passes but the portability and not having a very expensive extension cord are two major pluses.
If you budget can only afford the Clarke buy it you can always sell it.
T_Town_Baja
T_Town_Baja
Posted: Thu Jan 15, 2009 06:51 PM
Dont forget that the Lincoln versions sold at Homedepot and Lowes are not the standard version. They DO NOT offer Continuous voltage control. They are tapped, meaning that your voltage selection is a "click" style knob. The model from lowes is leaving off the C or T from the "140" most likely its tapped. (Can verify if the switch clicks or is a smooth selection)
Hobarts are GREAT welders for the beginner and they are cheap. They are infact Miller machines with some some minor differences in the drive gear AND they are tapped. Voltage is 1-4 (1, 2, 3 or 4) The miller version, millermatic 140 is continuous so you get 1-4 with infinite control. More for the advanced welder who really likes to fine tune. The miller 140 runs about 650, the hobart 140 is about $450.
Lincoln offer both tapped and continuous models. the HD/Lowes version are tapped. And Lincoln sells the same version, noted with a T or C in the model number.
If it was me buying the welder, i would go with the 180, the extra duty cycle comes in handy. I believe the 140's are a 20% duty cycle at 90 amps and the 180 is 30% at its max, meaning you can weld much longer on the 180 at the same rated output as the 140's max. Less downtime.
Just some info I have to offer, i am no means a professional, but I have been welding for a better part of a decade. Mainly fabrication as a hobby and automotive.
Blaine
JumpinBruceB
JumpinBruceB
Posted: Thu Jan 15, 2009 07:24 PM
Thanks you all for your opinions because im very unsure when purchasing anything really. So I think i am going to go with the 220 if it has a continuouss voltage control like t_town was saying. If it is tapped I will see if i can special order one from them that is continuous voltage. The big reason im going with one of these is im getting a 20% discount and 12 months no interest no payments soooo im just trying to capatilize on the situation while i can. I wil let you all know what i have done at the end of the day
Posted: Thu Jan 15, 2009 07:58 PM
12 months same as cash ,20%, off and continuos voltage control It does not get much better than that.
JumpinBruceB
JumpinBruceB
Posted: Fri Jan 16, 2009 02:55 AM
GREAT NEWS I CAN ORDER IT IN THE CONTINUOUS MODEL!!! So we didnt have a catalog for them but i checked online and got the model number and should be gettin it ordered tomorrow Smile Im pretty excited.
You got that right perrib I cannot pass a deal up like this.
One last question I am gonna order the 180 unless anyone feels it is just a waste and i should just get the 140...its about 150 bucks more for the 180
Posted: Fri Jan 16, 2009 03:45 AM
It depends on what you are going to do with it. The 180 amp unit should have a greater duty cycle and weld thicker metal in 1 pass. The 140 is probably 120 volt and can be used in more places. I actually want both.
This is the cart I made to make the 180 Miller more portable.
The 100 foot extension cord was not cheap.
Athlon64
Athlon64
Posted: Fri Jan 16, 2009 03:34 PM
Well unless your going to the more exotic metals, I use a high freq tig at work welding up cracks in stainless steel pipeing on the airport crash trucks and class A fire engines on foam systems and high pressure disscharge pipeing. I perfer a TIG for more finer and more percise control of heat. Migs are better for production work like assembly line work. Most of us can't afford the giant bucks for the big machines and a smaller machine will do just fine around the house. I can do stainless, alumnuim, and nickel, cast iron,and at that price its good enough for me. If I have to weld to coke cans together end to end with out putting a hole in them, then I take it in to work.
30 year triple Master EVT, ASE, heavy truck, automotive certified emergency vehicle mechanic
KooK
KooK
Posted: Fri Jan 16, 2009 10:39 PM
Personally I will only use Hobart or Miller welders. You really get what you pay for and they are amazing.
JumpinBruceB
JumpinBruceB
Posted: Fri Jan 16, 2009 11:35 PM
Ok so im not able to order the lincoln with continuous but i can order a hobart or a miller but they just are to far out of my price range. I guess i didnt think every thing through when i first started this venture So athlon i was wondering if when you said you were building a rail if you were using the tig welder on all that
No new posts New Members NEW WELDER IN GILBERT 2 BONEY 2081 Re: NEW WELDER IN GILB...
 Thu Apr 28, 2011 01:14 PM
BONEY View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Which welder is better?
18 Zoom153 14847 Re: Which welder is be...
 Wed Apr 16, 2008 04:59 PM
Sample View latest post
No new posts VW Volkswagen & Baja Bug General Discussion welder suggestion please 7 r8rfan66 2533 Re: welder suggestion ...
 Fri Jul 27, 2007 03:09 AM
MOCRAWLER417 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion engine choice to make 6 soopercoop 2695 Re: engine choice to m...
 Sun May 13, 2007 06:15 PM
1FASTHOE View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Anybody know a good/resonable welder? 10 mrscsi 5634 Re: Anybody know a goo...
 Sat May 06, 2006 09:30 AM
