Visitors: 122
Total: 122
20: Home
23: My Account
64: Home
67: Event Calendar
80: Garage
100: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wires out?
Wires out?
baja?
baja?
Post Post subject: Wires out?
Posted: Thu Sep 07, 2006 03:07 AM
I am trying to take the body off my 68 bug, just to see how everything looks and stuff, but am stuck on taking the steering column out. It is loose and everything except i cannot get the wires from the turning signal out and the ingnition wires out of the actual steering wheel assembly. Any suggestions would be welcome.
Post Post subject: Re: Wires out?
Posted: Thu Sep 07, 2006 04:52 AM
To take the wires out of the column you have to remove the wheel.
Why are you taking the column out? The body comes off the pan after you disconnect the steering shaft from the box and the horn wire. The rest if the wires stay with the body.
baja?
baja?
Posted: Fri Sep 08, 2006 03:25 AM
I am going on information i gatherd from a book from the library... aparently its incorrect.
69bapbaja
69bapbaja
Posted: Sat Sep 09, 2006 04:53 AM
disconnect them from the fuse panel and dthe flasher. Push the wire's back through the hole and then you disassemble the steering wheel. if you don't disconnect you will end up cutting.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
No new posts VW Volkswagen & Baja Bug General Discussion Spark Plug Wires 6 bajatink 2856 Re: Spark Plug Wires
 Tue Mar 20, 2007 05:06 AM
bajatink View latest post
