Members: 1
Visitors: 122
Total: 123
 Members:
01: Lucky7-11 > My Account
30: My Account
68: Event Calendar
81: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- welding on my Baha
welding on my Baha
Lakelizard
Lakelizard
Post Post subject: welding on my Baha
Posted: Wed Sep 06, 2006 08:46 PM
I have minor welding projects that i wanna do to my baha..Like tach welding and at the most building a custom bumper...I dont want a welding career..I just want an affordable solution that I can do at home..I wont use the welding often..What might yall recommend...What is line welding or feed welding?....What exactly do I need to start welding??I really want to do this myself if at all possible..Thanks this is a great forum,,Thanks for reading take care..
saltyslug
saltyslug
Post Post subject: Re: welding on my Baha
Posted: Wed Sep 06, 2006 10:02 PM
I got the $200 burn box at homo depo. it has worked great but alot of splatter. If I had a few extra bucks I would go with the next one up that you can use gas with(less splatter). I made sure mine had a problem before the warrany was up and got a new one, lol. It is the lincoln model. miller of coarse is the bling but you gotta have bling to get the bling bling, lol.
you can always use the flux core wire if you cant get the gas right away. don't buy the wire at the homo depot though, go to a welding shop. they come with a free role and you can buy 1 lb rolls for $13 or go to the welding shop and buy 2lb roll for $15, good times.
also buy a cheapo helmut at oak harbor that auto tints, you wont be welding full time so the cheapo should be fine. cheap leather gloves also. if you decide to get down and dirty with the welding then you need to get quality poop.
YOU DON'T HAVE TO BE A GOOD WELDER, JUST A GOOD GRINDER.
saltyslug
saltyslug
Posted: Wed Sep 06, 2006 10:04 PM
<<<<< private salt t nuts reporting for duty sir, lol. I said duty, LOL. sorry just noticed I moved up in rank.
Posted: Wed Sep 06, 2006 11:19 PM
i think what the slug was saying is, a burn box is a stick welder, and if you want to step up, go wire feed... you can buy both at harbor freight, sense you dont want to spend alot of money on something you'll never use... Wink i hope i translated that correctly for ya slugo.... Wink
Posted: Thu Sep 07, 2006 02:36 AM
NO HARBOR FRIEGHT!!!!!!!!!!!!!
their welders have more problems than a hooker with vd!!!!
go to home depot. get the book on welding (its next to the welding supplies). sit down and read through it.
to start out, a 120vac Lincoln mig welder is fine. it splatters a smidgen but gets the basics done. if ya go with a 240vac unit, it minimally spitts on your work and should be usable with various gases.
the difference between miller and Lincoln welders is the same as ford and chevy. which ever you prefer. My family has used Lincolns since the late 50's.
your best thing to do is aquire a usable welder. be it: mig, or arc (stick).
go out and pick up scrap steel to learn on before you TOUCH your projects. Wink
Posted: Thu Sep 07, 2006 04:48 AM
What he said! Wink
Posted: Thu Sep 07, 2006 12:26 PM
Anoter place to look for good/cheap is pawn shops. You can find a lot of good tools tht some one got ride of or stole on sale. (Air Comprsors) for one Smile
Posted: Thu Sep 07, 2006 03:15 PM
so h.b. welders are junk ? personal experience ? or word of mouth ? you can also check the newspaper for used ones, you never know... Wink
SandRacer
SandRacer
Posted: Thu Sep 07, 2006 06:25 PM
I started with a little 110 volt wire feed welder from Sears for under $200. Even though it came with the hook ups for the Argon bottle, I never added it. I just used the flux core wire. I used it for several years until I started doing a lot more welding and bought a 220 volt Miller Mig (off EBay).
Even with the splatter, the little 110 did a good job for little $$$.
1976 Baja Bug
72BajaBen
72BajaBen
Posted: Thu Sep 07, 2006 10:18 PM
im going to be purchasing another welder. i have an arc and it sucks. MIG is the way to go. im just going to be getting a cheap one, burt i never thought to look in a pawn shop. that is a good idea.
Posted: Fri Sep 08, 2006 01:43 AM
thats cause you arent usin it right. too much/ too little heat., wrong rod , etc..... my family has used lincoln arc welders since the 50's with no trouble.
they are not recommended for thin metals. anythin less than 3/16 - 1/4" is way to thin. even with a small rod.
Lakelizard
Lakelizard
Posted: Fri Sep 08, 2006 02:03 AM
Thanks so much for the great replys...The mig means its the linefeed style right? and the arc welding is the stick...I definatly dont want to go that route....It sounds like I should look for a 110 wire feed with argon hookups..and argon is some kinda gas that keeps it from splattering as much... Or use flux core wire and I wouldnt require argon...Ive got lots of investigating to do..ebay here I come..Thanks guys ...take care
Posted: Fri Sep 08, 2006 02:08 AM
like I said, go to Homedepot or a local welding supply (even use the internet. you have internet right??) and read the welding books that discuss the difference and techniques of the welders that are available. you can also weld with oxy/ acet, oxy/ nitro, etc. (gas welding)
even hit up the local library if your broke.
speedtrash
speedtrash
Posted: Sat Sep 09, 2006 08:10 PM
books are very important. i have a lincoln electric pro mig 135, came with a helmet,the lines and guages to hook up to a bottle, and a video that i still haven't watched for about 500. and i love it. i've hooked a bottle up to it and wow!, i felt like a pro. and with flux cored wire it does a great job as long as you know what you're doing. if you don't know what you're doing then you can grab a piece of scrap metal and figure it out real quick.
carpe diem
"sieze the carpe"
saltyslug
saltyslug
Posted: Sat Sep 09, 2006 11:10 PM
I agree NO harbor freight for the welder, but the masks are pretty cheap and if hes only doing it for pratice and minor baja welding it should be ok.
The biggest thing for me is not looking at the arch, look a lil away and then look right below or which ever way your welding. Pretty much just keep your eyes on the puddle and go slowly back and fourth, good luck man its easy, teachin the ol lady was hard, lol.
No new posts VW Volkswagen & Baja Bug General Discussion Trailer Welding? 2 Rickman 2343 Re: Trailer Welding?
 Tue Jan 31, 2012 03:37 AM
No new posts VW Volkswagen & Baja Bug General Discussion so...where were all the baha's ha's ha' ha's ???? 3 ikill6453 2251 so...where were all th...
 Wed Feb 23, 2011 07:33 AM
No new posts VW Volkswagen & Baja Bug General Discussion Welding Questions 13 Rickman 8273 Re: Welding Questions
 Thu May 13, 2010 10:56 PM
Billy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion welding problem... 4 Brettucks 2680 welding problem...
 Sat Apr 17, 2010 05:59 AM
Brettucks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion quick welding question 2 Brettucks 2159 quick welding question
 Sat Apr 10, 2010 08:31 PM
DONT View latest post
