Latest: slyster
Overall: 3568
Visitors: 249
Total: 249
20: Event Calendar
21: Pictures
23: My Account
27: Event Calendar
47: Event Calendar
48: Event Calendar
60: Home
62: Event Calendar
74: Event Calendar
93: Pictures
95: My Account
96: Pictures
104: Event Calendar
107: Garage
109: Event Calendar
118: Event Calendar
143: Event Calendar
154: Baja Forums
161: Event Calendar
162: Baja Forums
168: Baja Forums
173: Baja Forums
177: Event Calendar
180: Baja Forums
181: Baja Forums
182: Baja Forums
184: Baja Forums
189: Baja Forums
190: AMAZON.com
194: Garage
195: Baja Forums
196: Baja Forums
197: Baja Forums
198: AMAZON.com
199: Baja Forums
201: Baja Forums
202: AMAZON.com
204: Baja Forums
205: Event Calendar
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
212: Baja Forums
213: Baja Forums
214: AMAZON.com
215: Baja Forums
217: Baja Forums
218: AMAZON.com
219: Baja Forums
220: AMAZON.com
221: AMAZON.com
224: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: Baja Forums
228: Event Calendar
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: Baja Forums
234: AMAZON.com
235: Baja Forums
236: Baja Forums
237: Baja Forums
238: Baja Forums
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: Baja Forums
243: AMAZON.com
244: Baja Forums
245: Baja Forums
246: AMAZON.com
247: Event Calendar
248: Baja Forums
249: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- brake for combo spindle
DUBclub
DUBclub
Post Post subject: brake for combo spindle
Posted: Sun Dec 28, 2008 06:40 PM
My set up is 6" wider beam with no towers with 10" fox coil overs with king shocks, and 4" x 1.75" trailing arms, with 3" raised combo spindles, with HD rack and pinnion and offraod tie rods
what type of brake setup would be bombproof for my spindles...i have seen alot of brake setups blow up on the rocks here in the southeast and i need something that can take the abuse and im not used to alot of fabrications but i know people that can help...i was thinking somethign with steel would be nice...weight is not an issue for me duribility is more important....
thanks guys for helping out the noobs
Post Post subject: Re: brake for combo spindle
Posted: Mon Dec 29, 2008 04:35 AM
I have had no problems using stock 5 lug drums. The have held up to 19 yearts of rock and whoops with no problems. Race Trim , CNC, neal, AMS and other make off road racing disc brake set ups that is extremly stout. Also consider 33x9.50 front tires they absorb alot more shock than smaller tires. I have been using them for about a year they are a big improvement over the 700 15 Yokohamas I was previously using.
abcprint
abcprint
Posted: Mon Dec 29, 2008 04:55 AM
we are using (gear one) front disk brake kit and its works very good.
about $599.00 for the dual piston.......
66 Baja
abcprint
abcprint
Posted: Mon Dec 29, 2008 04:58 AM
we are using your exact setup for the front end except the the coil overs....Fox is what we use....
66 Baja
2180 Baja bug with 091 trans.
11 51BUG50 2358 Clutch and pressure pl...
 Fri Mar 10, 2017 07:22 PM
1 LittleBaja 1446 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 1438 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 2417 Re: Brake light switch...
 Sun Nov 17, 2013 07:21 PM
24 vwboat 8609 Re: lifted spindles an...
 Fri Mar 22, 2013 08:58 PM
